SHIFT linkage noise
Old Aug 25, 2002 | 07:25 PM
ANB Clothing Co's Avatar
Default SHIFT linkage noise
my shift linkage came loose the other day and dropped to the ground....it got bent, so the shop bent it back cause they couldnt find the linkage anywhere...and installed, now when i move the shifter all the way over to the left quickly it sounds like it is hitting something....it also feels a different...could someone tell me what that might be hitting and if its bad.....thanks
94HybridEX's Avatar
Default Re: SHIFT linkage noise (ProjectSpoon)
Get under the car and take a look.
It may be hitting the frame or some heat sheilds.
Old Aug 25, 2002 | 07:33 PM
memphiss13's Avatar
Default Re: SHIFT linkage noise (94HybridEX)
just buy a new one, if you have a friend at honda its cheap. i ordered one from the acura dealership that i work at and it was $50. the regular price was $80. also, do you have a short shifter, if you do it might be hitting your exhaust
Old Aug 26, 2002 | 12:30 AM
Default Re: SHIFT linkage noise (rookie2nr)
yeah i do have a short shifter...and when i move the shifter towards first quickly it sounds like its hitting something hollow, so ill check out my exhaust and see...
civicsi0721
Feb 25, 2009 07:14 PM
alscrx
25
Feb 9, 2008 07:44 AM
zenon8890
Apr 23, 2006 02:33 AM
loclowd
Oct 10, 2005 12:11 PM
erikiksaz1
Mar 28, 2005 01:51 PM
