Axles for crx 91 si whit b series swap.
Old Aug 17, 2009 | 08:45 PM
ricardo13d's Avatar
Default Axles for crx 91 si whit b series swap.
i will swap my b series engine from a eg6 on a 91 Crx, i need another axles? or i can use the same. thnks
Old Aug 17, 2009 | 08:56 PM
lunalink's Avatar
Default Re: Axles for crx 91 si whit b series swap.
u HAVE to use the axles that came from that swap..
the common thing is to use DA axles when you swap in a B-series into a EF..im sure you can use the axles that are on that swap..
Old Aug 17, 2009 | 09:35 PM
jhammond_82's Avatar
Reject Papi
i agreee, da axles are the most popular choice.
Old Aug 17, 2009 | 09:53 PM
crx_si-r's Avatar
or you can do like i did, and use some older teggy axles. im running 88-89 integra axles. no problems since i did my swap 4yrs ago
Old Aug 17, 2009 | 09:56 PM
guy_from_nerk's Avatar
90-93 teg axles w/o abs
Old Aug 17, 2009 | 11:22 PM
ricardo13d's Avatar
ok, DA axles are the common choice. but i can use the same axles of my eg6? sorry for my confussion. htnks again
Old Aug 17, 2009 | 11:28 PM
FOMULA91's Avatar
The EG & DC use different intermediate (half) shaft..... Not sure if the male/female intermediate haft are different in length, but DA/EF use the female style intermediate shaft...
Old Aug 18, 2009 | 12:37 AM
.Manny.'s Avatar
Touching My Member
x2
Just go get DA axles, and remember, the axle with splines running down the entire inner shaft goes on the driver side...passenger side has splines covering only half of the inner shaft.
Old Aug 18, 2009 | 11:20 AM
jonnyt1130's Avatar
if you plan on using DC axles be sure to get the matching halfshaft axles seal or else it will leak like a bitch
Old Aug 18, 2009 | 04:40 PM
redflaredcrx90's Avatar
if you runn a da intermedit shaft use da axles if you had ahad a dc intermedit shaft run dc axeles the the delsol with b16 and em1 and dc all used the same intermedit shaft and axels intermedit shafts from a auto do not work on a five speed trannies
Old Oct 6, 2009 | 01:37 AM
ungcobob's Avatar
i bought ebay axle to swap a b16a y1 tranny into a crx and installed everything correctly. Why is the driver side axle slightyly about a cm too long to put the knuckles back in place?
lsvtec_hatchback
Nov 5, 2015 08:21 AM
1337 Si
Sep 9, 2011 04:28 PM
Ajohatch
Northwest (Sales)
Nov 10, 2005 11:48 PM
Samurai
Sep 17, 2004 07:24 PM
JDMotive
Aug 4, 2004 08:54 AM
