Fuse #14keeps blowing
Old Aug 17, 2009 | 07:45 PM
civickiller's Avatar
Default Fuse #14keeps blowing
fuse 14, alternator solenoid keeps blowing. as soon as i turn the key on it blows.
any ideas?
also the grn/blk from the main relay, is it 12V from the main relay? if i cant fix this then im going to rewire for drag car.
thanks
Old Aug 20, 2009 | 07:58 PM
Default Re: Fuse #14keeps blowing
no one?
Old Aug 20, 2009 | 07:59 PM
enigma2446's Avatar
something is grounding out look around the engine bay for loose or open wires!!!!!
Old Aug 20, 2009 | 08:23 PM
checked engine harness, no open wires
Old Aug 21, 2009 | 03:49 AM
Bush-15's Avatar
Go up a size.
Old Aug 21, 2009 | 04:00 AM
fireant's Avatar
May also be a problem with the main relay or fuel pump.
Old Aug 21, 2009 | 08:13 PM
brand new main relay, ill check the fuel pump wiring.
i did go up a size and it started then died but it didnt blow the fuse
Old Aug 21, 2009 | 08:28 PM
MurphyEF's Avatar
getting any codes on your ecu?
Old Aug 24, 2009 | 08:38 PM
yes but its a distributor code, converted obd1
Old Aug 24, 2009 | 08:39 PM
what where is the alternator solenoid?
Old Aug 25, 2009 | 06:52 AM
jlicrx's Avatar
there is no alternator solenoid - fuse #14 is for the alternator AND the various solenoids - this is wiring diagram for fuse#14 which shows what all it controls
pettyboy69
Jan 25, 2010 09:32 PM
Jonny Rocket
Jul 12, 2009 09:27 PM
97civic07gsxr
15
Jan 14, 2009 06:25 PM
93turbo16
Jun 18, 2006 12:19 PM
