when is it time to change ur timming belt and water pump?
Old Aug 25, 2002 | 06:48 PM
JDM DC2's Avatar
Default when is it time to change ur timming belt and water pump?
i have 70k i wanna kno when should i change my timming belt and water pump...and should i change anything else?
Old Aug 25, 2002 | 07:03 PM
oneslowls's Avatar
Default Re: when is it time to change ur timming belt and water pump? (JDM DC2)
Usually it is recommended to replace them at 90k miles. You should be ok at 70k, but it doesn't hurt to do an inspection (i.e. premature wear or leaks).
Old Aug 25, 2002 | 09:07 PM
Volcom's Avatar
I got the timing belt and all the other belts done at 90K. I didn't have the water pump done and I am regreting it more and more. My water pump started liking at 120K and I now have 133K on the motor. Just wait until 90K and have all the belts and the water pump done at once.
Old Aug 26, 2002 | 06:47 AM
X2BOARD's Avatar
Default Re: when is it time to change ur timming belt and water pump? (Volcom)
Old Aug 26, 2002 | 10:08 AM
mugenracer's Avatar
Default Re: when is it time to change ur timming belt and water pump? (X2BOARD)
Do honda/acura in the US recommend that the timing belt be changed at 90k?
I have had 11 hondas, (5 JDM and 6 UKDM) and everyone of them (in the handbook) recommended the timing belt be changes at 60k miles. In fact every car i ever owned recommended 60k, so thats mazdas, toyotas, nissans, and hondas. i wouldnt feel safe going past 60k on the one timing belt!
Old Aug 26, 2002 | 10:23 AM
GSRaCeRbOI's Avatar
I think the interval is 90K for the first time.. and every 60K after that
Old Aug 26, 2002 | 10:34 AM
mugenracer's Avatar
Default Re: when is it time to change ur timming belt and water pump? (GSRaCeRbOI)
that may be true in the Us but 60k is recommended for first time over here. i always do mine at 50k just to be safe, although i changed the last one at 18k!!! i was getting head work done so decided that seeing as the belt was off i may as well put a new one back on. i also done the water pump too, even though it was only done 18k ago too!
Old Aug 29, 2002 | 11:39 PM
JDM DC2's Avatar
Default Re: when is it time to change ur timming belt and water pump? (mugenracer)
does it matter if its a gsr or not for when i should change my timming belt?
Tom B.
Sep 15, 2015 05:23 AM
spluvs2install
Aug 26, 2006 07:40 PM
95teggie
Apr 6, 2006 05:25 PM
1998hondaaccord
Sep 18, 2003 07:25 AM
parasonic
Jun 16, 2003 06:26 PM
