Noise coming from axle?
Around 7 months ago I hit a semi truck tire on the freeway and damaged my front end really good. I had the damage repaired and the collison shop said that my axle and all parts associated with it LOOKED fine.
After a few months I started to notice that the was a viberating noise coming from my front end. As time past it got louder and started to happen at a lower rate of speed. At first I would hear it at 80+ mph. Now I hear it at 30+. I feel it also and when I'm cornering the viberation slows.
What is wrong, axle, cv joints, does anyone have an idea!
If it's a knockong noise while turning, I would look at the outer CV Joint
P
I've seen the following make noises like this:
a) loose lug nuts
b) cracked rotor
c) bubble in the tyre tread.
If the noise should get louder when you turn, that will give you a hint on what side to look.
If it gets louder when turning right, then the problem is with the left side wheel assembly (You're putting more weight on it) and visa / versa
P
SDHonda153
Sep 26, 2012 04:48 PM
accord_raffi
Jan 26, 2009 03:34 PM
