Lighting HID/Xenon kits, Retrofits and Associated Topics
Left low beam out in EM1
Old Aug 16, 2009 | 12:53 PM
Jdw4rf's Avatar
Default Left low beam out in EM1
OK so I was driving and my left low beam went out, I pulled over and checked the fuse and it was fine but when I installed a new headlight the low beam was still out.
I tried two more different brands before coming to the conclusion it could be wiring related, since both high-beams worked and my right low-beam worked but not my left. The previous owner of the car had a p.o.s. HID kit on it that I removed but I didn't cut or loosen any wires from the harnesses. Any help would be greatly appreciated, my car is a 99 Civic Si, thanks!
Old Aug 16, 2009 | 07:43 PM
e46civic's Avatar
Default Re: Left low beam out in EM1
Headlights are individually fused, did you check one or both? If both are good and you changed the bulb its gonna be a broken wire (slight chance of switch or h4 connector, but I doubt it). I cant remember off the top of of my head, but there might even be a fuse for both high and low, if ball fuses are good, start lookin at grounds.
Old Aug 17, 2009 | 05:32 AM
Jdw4rf's Avatar
alright, thank you!
Bleakened
Oct 17, 2016 07:41 AM
pr1madona
Honda CR-V & Element
Oct 1, 2016 11:52 AM
civicpark81
Apr 23, 2012 07:50 AM
KOTULCN
Honda Civic (2001 - 2005)
13
May 5, 2010 07:34 PM
RSX_TypE-1
17
Jun 21, 2006 07:23 PM
