Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Honda Civic Trunk Latch
Old Aug 16, 2009 | 08:41 AM
Shaynepolevault's Avatar
Icon2 2001 Honda Civic Trunk Latch
Ok My trunk latch does not lock. it is either stuck in lock position or open position but it will not stay closed. My first question is if I can fix it what do I do, and my second is where can I buy a new trunk latch I looked everywhere and nobody has them let me know please thanks.
Old Aug 16, 2009 | 09:32 AM
2cams's Avatar
Default Re: 2001 Honda Civic Trunk Latch
cables broken, get a new one from the dealership. removed panels around trunk latch, b pillar panel and carpet inside trunk and pull the cable out with the new cable tied to it and hook up the new one.
Old Aug 16, 2009 | 11:52 AM
its not the cable becuse I had a carbon fiber trunk on it before and it closed.
Old Aug 16, 2009 | 02:54 PM
toyomatt84's Avatar
Sanji
http://www.fueldoorfix.com/
Old Aug 16, 2009 | 04:14 PM
00falcon's Avatar
mine is the same. it sometimes requires slamming to get it to close...
i even replaced it with a 01-02 accord opener to get keyless... though that did reduce the force required to close it.
Old Aug 16, 2009 | 06:01 PM
dr_spock's Avatar
I had to adjust the striker on my trunk latch to get it to close and stayed closed. I guess over the years, it slowly worked itself downwards until the latch had trouble catching it. I found that out when I stuffed myself in the trunk and watched it closing. I loosened the two bolts and moved the striker up a bit.
Old Aug 16, 2009 | 08:55 PM
[Edil]clyde's Avatar
go hit the junk yard and get a new latch.
Old Jan 20, 2011 | 01:51 PM
cydisc's Avatar
I tried this on mine, but it was already as far up as it would travel. I removed it and discovered that it was actually bent at the base of the loop. So, I flipped it over and reinstalled it and that worked.
Old Jan 20, 2011 | 03:09 PM
It Wasn't Me's Avatar
Ordinarily someone might complain about such an old thread being bumped.
I'm just glad that you searched before making a thread!
KashMillien
Jun 8, 2015 02:12 AM
loopyjuju
Jan 2, 2012 03:04 PM
Agent_Samz
Dec 17, 2009 03:19 AM
Nathan read
May 8, 2008 09:17 AM
