Need help with TPS replacement
Old Aug 16, 2009 | 07:53 AM
guitarguru87's Avatar
Default Need help with TPS replacement
Hello all,
I have an 88 CRX DX and it was throwing a TPS code (7). I bought a blox TPS that is supposed to work for all D, B, and H series engines but its not the same as the one I pulled off of mine and it will not work. I attached a pic of the new and old one next to each other. The old one turns clockwise and the new one turns counterclockwise. It's almost like the are mirror images of each other. Any ideas why this is and what am I supposed to do?
Old Aug 20, 2009 | 06:53 AM
Default Re: Need help with TPS replacement
bump for info?
Old Aug 20, 2009 | 08:29 AM
Gunmetal_B20_Hatch's Avatar
Get a used TB from a junkyard.
Old Aug 21, 2009 | 07:30 AM
traxxasx's Avatar
Your problem lyes within your engine.. If i am not mistaken you have the d15 motor which is still DUAL POINT correct? If its not mpfi then that new tps wont work. EVery tps is the exact same BESIDES the dual point tps which spins the oppisite direction and will not work. So basically if you need a tps you have to get one off another dual point manifold.
Old Aug 23, 2009 | 07:43 PM
Ok, that makes sense. I am fighting eBay now because the seller advertised that it will work with the d15. Thanks for the info.
Old Aug 24, 2009 | 01:19 AM
~sp33~'s Avatar
EFB055
It probably works with MPFI d15's, so i don't know if you have much of a leg to stand on. Did you ask him the exact engine you had planned to put it on? IE: d15b2, or did you just ask d15?
solo227
Apr 22, 2009 12:07 PM
h22_crx
Apr 3, 2006 06:14 PM
VeilSide_Mas
Aug 1, 2005 04:46 PM
SC0TT
Jul 30, 2003 09:10 AM
D1ANCER
Apr 5, 2002 01:25 PM
