forgetting to shift
alright this may sound stupid but I was driving my 08 acura TL and i put it into sport shifting mode and I had it one 1st gear and when I was speeding up the hill I forgot to shift to 2nd before it redline so then you just heard the engine screaming and the tachometer meter is bouncing up and down and then I just shift to second and I was wondering did I do any damage?? I basically forgot to shift.
The TL should automatically shift into the next higher gear when in sport mode once you hit the limiter the third time.
you're fine...have you ever seen the videos of guys trying to blow up a single cam in an old hatchback? damn thing bounces off the limiter for minutes and still doesn't want to die.
I hit the rev limiter on a near-daily basis with my 261,000 mile D16 engine. It's fine. (Kind of surprised it hasn't spun a rod bearing yet since D16 rod bolts like to stretch when run above 7000 RPM constantly.)
If you had damaged it in some major way, you'd have known immediately.
