Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2002 civic a/c is on when turned off
Old Aug 16, 2009 | 12:16 AM
antman1's Avatar
New User
Default 2002 civic a/c is on when turned off
my 2002 civic ex a/c wont turn on (manual switches) unless i turn it off it worked fine till i swapped the compressor with a junk yard unit. when in the off pos.it does run but does not cycle and causes fog at vents from freezing i guess and sometimes blows off the safety valve to release excess pressure the reson for changing comp was because the pulley bearing was shot and made a lot of noise ,gee i'd rather have the bearing noise also tried to get codes and none show up to sum it up ac doenst turn when switch is in on pos. it does come on when i turn switch to off but it stays running even when fan is in off weird huh?
jaebekae
May 21, 2017 07:52 AM
kruiz15
May 10, 2016 02:33 PM
Grant1234
Sep 10, 2008 08:32 PM
freddy_hung
11
Sep 21, 2003 07:32 AM
