fast blinker buggin me
Hello
Is it both right & left that blink fast or only one side? Do the both blinkers work on the side(s) that blinks fast?
I know I just had a problem with the socket on my EF where it was bliking fast for know reason both front and back blinked just fast. Fianlly after messing with the wires and reseating the bulb it worked right.
just the right side... the left is fine but right side is blinking fast... and the bottom right(passenger) marker on the bumper does not blink at all all wires are fine do i need to change something?????
if the lights not working change the bulb again it might of blew out. i have had that happen the bulb i just put in blew after i got done putting it in. it might be the socket has it gotten wet?
thanks for a the help guys... but it still does not work... changed the bulb again and the socket... does anyone know how to wire it from the fuse box???? ... or could it be the relay.. work on it yesterday till dark..and getting a little frustrated... and the corner marker does not work when i took a second look...
I figures out what the prev. owner did to these lights! lol he wired up the front bumper blinkers as amber light/fog lights! I returned them to factory blinkers and it is fixed.
Check on that. Maybe your cars wired like mine was.
i wanna figure this out so i can fix it .. mechanic quoted me 65 bucks to fix...
i don't wanna pay that much if its a cheap 10buck fix..
other than that thanks for the suggestions so far..
If it's a fast blinker, all bulbs changed, it's a wiring issue, check for any wires bent or chaving the frame... causing a short... last thing to trouble shoot is new relay for lights...
JDMEK-4
Mar 30, 2010 05:16 PM
or cut and splice ita up to you..
