wastegate springs..Tial.vs.synapse
i currently have a tial 44mm WG. im wondering if i can use the12psi spring from that Wg and use it in a 50mm synapse WG.. are the springs interchangable? anyone know wut psi the green synapse spring is? thanks in advance
Im going to go with no on this one. Remember that the spring is also acting against forces that the exhaust is putting on the WG. as well as boost going in to open the diaphram. I would think since the 50mm is bigger then there is more force from the exhaust, which means that the spring would have to be a little stronger than the 44mm spring. If it does fit in the diaphram housing it may turn out to be like 10 psi because of more force. Then again I may have totally missed on this one because I always just use the right springs
I'm just curious why you would wonder about this? If you order a Synapse wastegate (which I wouldn't after the way they falsely attacked TiAL in the beginning, and because they are expensive Made In China products), I would hope it would come with a spring. . . Also, I think they are supposed to be adjustable, aren't they?
