no idea what's wrong
Old Aug 25, 2002 | 04:29 PM
JackoliciousLegs's Avatar
Default no idea what's wrong
The problems with my car seem to be never ending... i hope this is it. I just replaced the clutch and front right axle. Anyways, when the car was on the lift, the mechanic told me that the front left axle needs to be replaced as well. Then as I was driving it yesterday, it started making a clacking sound from the front end. It seemed like it was making the sound when i went over bumps, but i can be going on a straight road, and i still hear it. It's not only when i turn either. Oh, and it's not consistent with the rotation of the axle either... as in, it's not a clack.. clack.. clack.. It's a clack... silence... crack crack. I only hear it at low speeds (under 30) and I can feel the vibration from it very slightly in the floor.
There were a couple things i thought it might, and I just wanted to get your opinions:
1. ball bearing/joint
2. engine mounts
3. left axle (maybe a boot??)
If anyone has input, lemme know. Thanks, JackO
Old Aug 25, 2002 | 04:33 PM
bullz's Avatar
Default Re: no idea what's wrong (JackoliciousLegs)
I think it might be your hub/bearing worn out. That is what happened to me. To check it, just spin your wheel hub w/o the tire and it should sound very rough and kinda uneven rotation. I replaced my knucke hub assembly and it was fixed.
Old Aug 26, 2002 | 03:35 PM
oatsuzn's Avatar
well if he told u the left axel is bad, thats probably what it is. awhile after the boot tears, u will hear that sound. u should get it replaced, if u havent already done so.
Old Aug 26, 2002 | 04:32 PM
iH8RICERZ's Avatar
I feel you on that brother!!!
Old Aug 26, 2002 | 09:31 PM
Default Re: no idea what's wrong (Lord Titus)
How hard are you driving this car to need new axles?
I've only had it a month. It's got 80k. I've had to replace the:
shifter (guy ghetto-rigged the old one)
clutch
fluids (of course)
clutch master + slave cylinder
front right axle
and now i guess front left?
Ferio4ya
Nov 25, 2009 10:57 AM
95_Civic_4dr
Sep 6, 2009 02:38 PM
Bush-15
May 26, 2009 09:46 AM
maskedSONY
May 2, 2003 04:52 AM
H22Prelude
Apr 21, 2003 08:18 PM
