Blinker light stuck on - electrical problem
Hi there, i'm having a very frustrating problem and I don't know where to even get started. I have a 95 honda accord. The passenger side blinker side marker light gets stuck on every couple times I turn the car on and it stays on even if everything else is off. The only way I can get it to turn off is by disconnecting the battery and once I reconnect it then it will be off. And it seems totally random when it decides to come on. Now here's the kicker - when the light is stuck on then the rear window defogger AND the first click on the wind shield wipers does not work.
But once I disconnect and reconnect the battery then everything works just fine. I've checked all the fuses.
Any help, suggestions, advice or anything would be greatly appreciated. Thank you
bcdinh
Oct 16, 2012 11:42 AM
BLKFLSH
14
Sep 29, 2008 06:51 PM
idontknowwhatimdoing
Jul 31, 2007 06:01 PM
