Honda Accord 05 V6 Air Bag Light -Help-
Hello everyone,
My 05 Accord V6 air bag light led up every once in a while on my instrument but I don't know how to reset it. Could someone please show me how to reset it?
Thank you in advance!
Re: Honda Accord 05 V6 Air Bag Light -Help-
The airbag light could be caused by the driver's seatbelt buckle, which is covered under the lifetime seatbelt warranty. The only problem is, if the seatbelt buckle is not the problem, the dealership will probably charge you for diagnosis. Do you feel lucky? Try this: Buckle the seatbelt, then turn the key to on (position II). If the light goes out, and stays out, the buckle is likely the problem, and IMO you should take the chance that you can get it fixed free of charge. If the light goes out for a second, then comes right back on, you might have another problem causing the light. Re-setting the light will not help, if the problem is not corrected. If you fix the problem, the light will go out on it's own, without having to re-set it. Good luck
carbonfibersi
03-10-2005 02:57 PM
