Del sol e brake woes
Old Aug 15, 2009 | 10:48 AM
kris.is.awesome's Avatar
Icon6 Del sol e brake woes
Okay, I did a rear disk conversion on my sol. The first set of cables was too short, and this set isn't right either. Ill let the pictures do the talking.
Cables attached correctly, adjustment backed all the way out.
Here, you can see the cable just isn't long enough.
The cable as a whole is also too long
Old Aug 15, 2009 | 11:06 AM
Anon51's Avatar
Default Re: Del sol e brake woes
what ebrake cables did you get? cuz si lines should work perfectly and what rear discs. (assuming they're tegs)
Old Aug 15, 2009 | 12:27 PM
They're da disks. First cables were also da. I think these cables are dc.
Old Aug 15, 2009 | 07:35 PM
Nbboy7's Avatar
Get some del sol si brake cables
Old Aug 15, 2009 | 09:36 PM
HiProfile's Avatar
The reason they won't fit right is because the del sol has a one-off possition and height for the e-brake handle. Many things on that chassis are del sol-only. As mentioned above, the VTEC model had the right cables, maybe the SI but I'm not sure. Basicly if it had disc brakes and it was a del sol, it's the right cable.
Old Aug 16, 2009 | 12:12 AM
ImportHatch's Avatar
Pm sent.
Old Aug 16, 2009 | 11:11 AM
Originally Posted by ImportHatch
Pm sent.
What a lifesaver.
Thanks man, PM'd back.
424racer
15
Apr 25, 2010 07:48 PM
310HPS2k
10
Mar 13, 2009 05:45 PM
delslo93
Jun 29, 2006 04:02 AM
AzntaggeR
12
Aug 6, 2005 04:04 PM
275Performance
Feb 8, 2004 06:56 AM
