Speedometer needle wobbles at certain speeds...
Old Aug 15, 2009 | 07:37 AM
Diversion's Avatar
Default Speedometer needle wobbles at certain speeds...
99 Civic Si - It does a shaky/wobble thing around 60 mph or so till 70 mph.. Whats usually the cause for this? Is it the cluster or is it the signal the cluster is receiving? Is there a speed sensor?
Div
Old Aug 15, 2009 | 07:58 AM
Jdm John's Avatar
Default Re: Speedometer needle wobbles at certain speeds...
Ya its probably the speed sensor.
Old Aug 17, 2009 | 03:19 PM
Diversion's Avatar
Bump for other thoughts!
Old Aug 18, 2009 | 04:11 PM
jadziasman's Avatar
What's the odometer read? My 92 Civic has over 240K miles and the speedo only works when it wants to. The VSS is not the issue, it's the printed circuit board that fails from bad solder joints. Your 99 seems a bit young to be experiencing this problem but your symptoms were exactly what my speedo was doing before it really started acting up. Sometimes it doesn't leave 0 mph; sometimes it reads 90 when I'm driving 70 mph. I have a GPS and a tachometer so I don't worry about the speedo even though it would be nice if it worked properly.
Old Aug 23, 2009 | 10:41 AM
Diversion's Avatar
112k on the ODO. I have a spare cluster that I could swap the printed board out with I suppose. That's a good place to start atleast, thanks.
mikehawk
Nov 5, 2008 10:04 PM
bboyjimpy
16
Mar 16, 2008 06:28 PM
HULKHATCH10
15
Jul 12, 2005 09:27 PM
slow4dr
Dec 27, 2004 07:19 AM
imadigitalgod
Oct 31, 2004 02:57 AM
