Anyone had problems with their 'high End Tri-Y headers by LogicMotorsports.com'
Damn, I did look twice on where to post, this was the most related forum. I'll get it moved to somewhere else. But Where dude?
Is it the same as this one?
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/review-big-tube-header-sublimnal-2625367/
Nah bruh, its this one https://honda-tech.com/forums/showth...t=SMSP+REPLICA
most people don't buy stuff here, but they are pretty cool, so if you can grab a pic of the welds they have i am sure anyone here can tell you if it is good quality or not ( judging by the welds) which is usually a good judgment since most of the companies probably use the same materials supplier.
shouldn't runners be paired 1-4 and 2-3 for an n/a header for the same reasons they are paired that way on a divided turbo manifold, or even on the factory 4-2-1 headers??
Nope, there has been so much R&D over the years for NA headers and I believe this is probably the 6th knock off header that's being made. Let's not go backwards in time, especially from pairing combination that was known to be ideal from a good 8-9 years ago... Feels like this fab forum is still in the stone ages of performance except for a bunch of cavemen who only does welding...lol
so does this go for any n/a header? i was always under the impression that pairing a runner with the next runner in the firing order of the same bank was the best way to pair them for maximum scavenging, and similarly when you make a 4-1 collector if possible you should put the primaries so that they fire clockwise/counterclockwise instead of across from each other.
kulo
Aug 15, 2009 05:37 PM
