92 EG LS/VTEC wont start
Old Aug 14, 2009 | 09:28 PM
vtecvu's Avatar
New User
Default 92 EG LS/VTEC wont start
I have a 92 hatch with a built ls/vtec running hondata s200 on p72. I was sitting at a redlight and the car shuts off. Im not getting power to the pump, and the pump has been tested and its good. When I hotwire the pump, my injectors arent pulsing. I dripped fuel into one of the cylinders and after trying to start, the plug remains wet. No spark. With key in the on position, the CEL stays lit as well as oil light. Car does crank. Ive already replaced the main relay. Can any persons help me?
Old Aug 14, 2009 | 09:35 PM
Former User's Avatar
Default Re: 92 EG LS/VTEC wont start
You lack both spark and fuel and the CEL is on, right?
When you jump the 2P service connector above the ECU, does the CEL still remain on steady?
Start by checking whether fuse 31 under the hood or fuse 18 or 24 under the dash is blown.
Old Aug 15, 2009 | 07:25 AM
vtecvu's Avatar
New User
It was the ACG fuse. Thanks!!!
Old Aug 15, 2009 | 07:29 PM
michaelzuniga89's Avatar
Whaat are fuses 18 and 24? Like what are they connected to?
Old Aug 15, 2009 | 07:36 PM
Fuse 31, 18, and 24 all supply power to the main relay.
Old Aug 15, 2009 | 09:01 PM
is that diagram similar to a 98 ek?
Old Aug 15, 2009 | 09:06 PM
No, the diagrams are specific to 92-95 Civics. For a 98 Civic, the equivalent main relay fuses are 44 (hood), 31, and 13 (dash).
Old Aug 15, 2009 | 09:10 PM
thank you..your a real help bro
speedpro92
Dec 30, 2010 11:04 AM
b16hatch620
Sep 19, 2010 06:42 PM
byc_cb7
47
Feb 6, 2010 12:01 PM
si90rex
Jun 24, 2007 05:53 PM
EJ1_203
Sep 10, 2006 04:36 PM
