How do I determine what EG I have??
Old Aug 14, 2009 | 08:52 PM
Moto-mac's Avatar
Default How do I determine what EG I have??
I keep seeing these different eg2, eg6, eg9, etc, what is the difference between the numbers???
my ride is a 1992 cx hatchback so what would it be?
Old Aug 14, 2009 | 08:53 PM
kmeng's Avatar
Default Re: How do I determine what EG I have??
eg6
Old Aug 14, 2009 | 08:58 PM
Moto-mac's Avatar
thanks, what is the difference between the other numbers
Old Aug 14, 2009 | 09:02 PM
ALLxMOTOR EG's Avatar
Vietnamese!
This is from the FAQ's stickied at the top of the forum.
http://members.lycos.nl/hendrik/honda/vin.htm
Old Aug 14, 2009 | 09:04 PM
kmeng's Avatar
eg2 is del sols, eg6 are 92-95 hatches, and i think eg9's are sedans
Old Aug 14, 2009 | 09:05 PM
TorquelessEM1's Avatar
If you want to be correct about it,its an Eh2..... We are not in Japan( at least I am not)
Old Aug 14, 2009 | 09:37 PM
forcefedferio's Avatar
Originally Posted by kmeng
eg6
thank you
thank you
Old Aug 14, 2009 | 11:48 PM
wangkata's Avatar
bingo!!!
Old Aug 14, 2009 | 11:53 PM
EusebioSam19's Avatar
unless its rhd its an eh2
eg6- civic hatch SiR
eg4- civic hatch vti?
eg2- Del sol
eg8- EG sedan?
Old Aug 15, 2009 | 12:38 AM
gilbert90605's Avatar
ITS CALLED A CHASSIS code.
if your wondering where its located on your car, take a look at your VIN(vehicle identification number) number.
Vehicle Descriptor Section. These 5 characters occupy positions 4 through 8 of the VIN and may be used by the manufacturer to identify attributes of the vehicle. Identifies vehicle features such as body style, engine type, model, series, etc.
Old Aug 15, 2009 | 05:41 AM
batallic's Avatar
eg6
no... seeing how thats the jdm sir, check yur vin xhgEH2xxxxx, u u got the CX so it will be EH2, Eh3 is the Si
Old Aug 15, 2009 | 07:44 AM
And for the person that asked,92-95 coupes are either EJ1 or EJ2...... remember kids,we are in the states. NOT Japan. So be carefull rambling off those JDM nutswinger codes..............
Old Aug 15, 2009 | 11:24 AM
whats wrong with saying the codes?
they do apply to all cars (from 1980+) no matter where they are from.
Old Aug 15, 2009 | 11:36 AM
awdgsx96's Avatar
There isn't anything wrong with using the code generically IMO, such as EF/EG/EK. It's the spread of misinformation that isn't right. Look a few posts up to see what I'm talking about.
Old Aug 15, 2009 | 11:38 AM
wdissident's Avatar
look at your vin number dummy
Old Aug 15, 2009 | 11:46 AM
Murk 'EM's Avatar
the vin wont show wich it is it will if its from japan ie.. my accords vin starts with J and has CD someware in the vin number(95 accord 4door in japan are CD5) my hatch is a 92 vin starts with a 2 and there is no EG in the vin number the closest thing to it is the first 4 are 2HGE..
Old Aug 15, 2009 | 11:53 AM
geneeunit's Avatar
its the 4,5,6th digits you look at..
disregard 2HG.. and then it would be something like EJ1 EJ2 EJ6 EJ8 EH2 EH3..
if your car is from the US.. its not going to say "EG" because it IS NOT an eg, same goes for ek. all us hatches are EJ6's
Old Aug 15, 2009 | 11:58 AM
Kyle is raaddd's Avatar
Ra-ta-ta-tat dat GDD
Old Aug 15, 2009 | 12:05 PM
HERE YOU GO>> LETS YOU KNOW all OF THE characters
How to read a VIN
1st character- Identifies the country in which the vehicle was manufactured.
For example: U.S.A.(1or 4), Canada(2), Mexico(3), Japan(J), Korea(K), England(S), Germany(W), Italy(Z)
2nd character- Identifies the manufacturer. For example; Audi(A),
BMW(B), Buick(4), Cadillac(6), Chevrolet(1), Chrysler(C), Dodge(B),
Ford(F), GM Canada(7), General Motors(G), Honda(H), Jaquar(A), Lincoln(L), Mercedes Benz(D), Mercury(M), Nissan(N), Oldsmobile(3), Pontiac(2or5), Plymouth(P), Saturn(8), Toyota(T), VW(V), Volvo(V).
3rd character- Identifies vehicle type or manufacturing division.
4th to 8th characters- VDS - Vehicle Descriptor Section. These 5 characters occupy positions 4 through 8 of the VIN and may be used by the manufacturer to identify attributes of the vehicle. Identifies vehicle features such as body style, engine type, model, series, etc.
9th Character - The check digit "character or digit 9" in the sequence of a vehicle identification number (VIN) built beginning with model year 1981 (when the 17 character digit format was established) can best be described as identifying the VIN accuracy.
A check digit shall be part of each vin (since 1981) and shall appear in position
nine (9) of the VIN on the vehicle and on any transfer documents containing
the vin prepared by the manufacturer to be given to the first owner for purposes
other than resale. Thus, the vins of any two vehicles manufactured within a 30
year period shall not be identical. The check digit means a single number or letter
"x" used to verify the accuracy of the transcription of the vehicle identification
number.
After all other characters in the VIN have been determined by the manufacturer
the check digit is calculated by carrying out a mathematical computation
specified. This is based on vin position, sample vin, assigned value code,
weight factor and multiply assigned value times weight factors. The values are added and the total is divided by 11. The remainder is the check digit number.
The correct numeric remainder - zero through nine (0-9) will appear.
However, if the remainder is 10 the letter "X" is used to designate the check
digit value/number.
10th character- Identifies the model year. For example: 1988(J), 1989(K), 1990(L), 1991(M), 1992(N), 1993(P), 1994(R), 1995(S), 1996(T),
1997(V), 1998(W), 1999(X), 2000(Y)------2001(1), 2002(2), 2003(3)
11th character- Identifies the assembly plant for the vehicle.
12th to 17th characters- VIS - Vehicle Identifier Section. The last 8 characters of the VIN are used for the identification a of specific vehicle. The last four characters shall always be numeric. Identifies the sequence of the vehicle for production as it rolled off the manufacturers assembly line.
Old Aug 15, 2009 | 06:24 PM
LOL......You said it....You guys and your EG6987435678.115. Jesus.........
Old Aug 15, 2009 | 06:30 PM
batallic's Avatar
lol apparently the whole 92-95 are EG`s hahaha
Old Aug 15, 2009 | 07:59 PM
ej1love's Avatar
lol @ nonsence in this thread
Old Aug 16, 2009 | 10:32 AM
No,here in the UNITED STATES they are either EH(hatch) or EJ(coupe).................Which is what I have been trying to say alllll along.In JAPAN it's an EG.
Old Aug 16, 2009 | 12:52 PM
austinkli's Avatar
It's most definately in the VIN number. I saw somebody say something about it not being in there, I believe it's the 4th and 5th and 6th characters. For instance, I have a USDM 92 Sedan, so I have an EG8.
Old Aug 16, 2009 | 01:05 PM
wdissident's Avatar
it is in the vin number. like my eg coupe says ej1. thats correct. i do have an ej1... dont make things harder then they are please. its just a honda
