93 Del Sol Aux Lights
I have checked all the fuses and they r good, when I turn on the aux switch it lights up but the aux lights don't come on. I tried them with the low and high beams and still nothing.
Any ideas where I should look?
Thanks in advance
I checked for voltage at the light sockets and nothing, next I'll check the fog light relay
Thanks in advance
the wiring behind the switch is very tiny, you could have a break in the wiring somewhere, but if there is a relay like you say, check that and make sure you check any fuses that might encompass the auxiliary lights.
I just picked up a '94, and the same thing happened to me ended up being the bulbs... on a side note the interior dome light and trunk light also weren't working, and it turned out that the fuse for these lights was simply removed, I replace the fuse and they worked.
