fresh motor and now no antilag pop
Old Aug 14, 2009 | 08:20 PM
boosted91crx's Avatar
Default fresh motor and now no antilag pop
I got my car back together and running today , nothing is changed in the set up other then its a fresh block replacing the one i cracked a sleeve in, my antilag used to crack like crazy, now its so quiet, it seems to build some boost but its much slower it used to crack like twice and i would be full boost. what are some reasons for this? the only variable is fresh block, fresh bearings, fresh rings and bearings and a fresh valve adjustment. my turbos exhaust wheel did get some minor tattering from pieces of the sleeve getting spit out threw it but it seems to be fine. i also confirmed all my settings in neptune and they are the same as they was before.
Old Aug 14, 2009 | 08:55 PM
boosted2.4's Avatar
Default Re: fresh motor and now no antilag pop
how bad is the exhaust wheel??? thats the only thing i can think of...
Old Aug 15, 2009 | 06:29 AM
boostedcivicsir's Avatar
Mr. Badwrench
how is the initial timing?
Old Aug 15, 2009 | 06:49 AM
i marked the dizzy and put it right back where it was, so the timing is exactly how it was as well.
the exhaust wheel seems ok.
Old Aug 15, 2009 | 06:55 AM
boostedh22a's Avatar
This probably sounds stupid, but did you confirm timing with a timing light?? Not just a marked distributor? If the engine is mechanically timed different, that would effect it. Also, a new motor will probably have better valve seal, etc. I would think that would change it too.
I just put a new head on my car, and had to mess with the launch control a ton.
Old Aug 15, 2009 | 07:10 AM
well i havnt checked it with a light but i can, i also know that my valves and valve train are much much quieter now, it sounded like a type writer before and now you barely hear so much of a tick, i set the exhaust all to 7-8 and the intake all to 6.
Old Aug 15, 2009 | 03:05 PM
pgpbubble's Avatar
Check the timing with the light. What is actual timing on the Anti-lag?
Old Aug 15, 2009 | 04:29 PM
problem solved, some how my settings got changed in my original tune file so that the rpm was only 6000 i set it back to 7000 and now it cracks like a banshee again. i think i might have accidentally saved over my original tune file at some point when i was in a hurry to close teh laptop and get staged while in the staging lanes. of course the tach just jumps so i had no clue it was only going to 6k. oh and i checked my timing and its all spot on.
Old Aug 16, 2009 | 01:57 PM
Ls_dx's Avatar
Cool. glad you got it figured out.
accord2civic2prelude
Dec 19, 2009 07:46 AM
fredtoast
May 20, 2003 11:36 AM
Tx92AccordExD
Jul 22, 2002 11:13 PM
