View Poll Results: FULL GSR swap with 110k miles for $2000. Good Deal?
Yes Great Deal buy that SOB
10
47.62%
No Bad Deal
19.05%
Average Deal
33.33%
Voters: 21. You may not vote on this poll
Full GSR Swap $2000 good deal?
Old Aug 14, 2009 | 07:50 PM
braddubya's Avatar
Default Full GSR Swap $2000 good deal?
$2000 for EVERYTHING needed for the swap. Engine trans ecu axles etc etc
says it ran great and has 110000 miles.
what do you guys think?
Old Aug 14, 2009 | 07:58 PM
braddubya's Avatar
Default Re: Full GSR Swap $2000 good deal?
and please say why you voted what you did! Thanks
Old Aug 14, 2009 | 08:16 PM
raidacaipo's Avatar
well its not that bad for the price.. you can always rebuild it or maybe even setup a poor man type R before you even do a swap but its your call.. is it a jdm gsr or a usdm gsr? comes with receipt if any?
Jdm John's Avatar
I think its an alright deal. Did you hear it run before it was pulled? and do you know the guy thats selling it?
Old Aug 14, 2009 | 08:19 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Not bad.
Old Aug 14, 2009 | 08:23 PM
thumper64's Avatar
Not a bad deal, but I'd be a bit leary if it's already out of a car unless you plan to rebuild before running it. Maybe something's wrong with it. If not, that will be about $1000 less than one from HMotorsonline will be, though higher miles. Either way, replace the timing belt, water pump, main seals...
Old Aug 14, 2009 | 08:24 PM
braddubya's Avatar
Im not ready to put more money into it yet. Its usdm.
No and No but it has title and was recently pulled from a frame damaged teg and he has pictures of the original teg with odometer
Old Aug 14, 2009 | 08:26 PM
Fatboycivic509's Avatar
Its easy to switch a Gauge cluster with lower miles then the Car accually has.
Old Aug 14, 2009 | 08:28 PM
Jdm John's Avatar
I would get the engine but before that I would run a carfax just to see if he is lying or not.
Old Aug 14, 2009 | 08:29 PM
braddubya's Avatar
yes but its also a $1200 savings over hmotors. I think it might be worth the risk.
Earthworm Jim's Avatar
Because for the $1200 more you can get a motor with less than 25,000 on it.
Old Aug 14, 2009 | 08:32 PM
Worth the risk of having a motor that might smoke, or a Tranmission that is bad?
What if one of the sensors broke when it got hit in the wreck?
If you think its worth saving $1200 for an engine that might be ok? well its your money
I just think for $1200 its worth not having to maybe deal with issues.
Old Aug 14, 2009 | 08:33 PM
raidacaipo's Avatar
well I sold my 96 jdm gsr complete with ecu but without axels, motor mounts, or shiftlinkage for $2300. I bought the motor from HMO too. Had only 40k miles when I sold it. Nothing wrong with it either.. in perfect shape
Old Aug 14, 2009 | 08:34 PM
Jdm John's Avatar
Old Aug 14, 2009 | 08:39 PM
braddubya's Avatar
Its actually in the HT marketplace
Here is the link
http://hondamarketplace.com/showthread.php?t=2616581
Old Aug 14, 2009 | 08:42 PM
Jdm John's Avatar
I would still run a carfax. Thats just me tho
Old Aug 14, 2009 | 08:43 PM
Here is the link
Hmm so the Engine was Def. raced with. It looks like its dirty as hell, and might have 110k miles (from what the gauge cluster says).
If you think saving $1200 from a CLEAN engine with 25k miles, new reman axles is worth it over a Dirty 110k mile Swap that is your call man your money.
From all you know, that swap could have bad axles, bad sensors, throws a Check engine light.
But thats the risk of saving $1200
Old Aug 14, 2009 | 08:51 PM
braddubya's Avatar
but with 1200 I could have it rebuilt and then some. I do see your point though...
Old Aug 14, 2009 | 08:55 PM
I just was like you, wanted the best motor for the cheap possible place I could buy it from.
It was the last time I ever bought cheap again. Which is why I went to HMO and paid the premium. I am glad I made the decision, Because the LS swap i got for CHEAP had so many problems, with no good warrenty.
It was a lesson learned.
If you wanna be quick, and do it, do it right the first time
Either way good luck with your choice man GSR is the way to go
Old Aug 14, 2009 | 09:42 PM
xXB18EKHatchXx's Avatar
Going cheap tends to bite you in the end. Hrm, wonder if I can sue Tiger Japanese.....
Old Aug 14, 2009 | 10:39 PM
fungus mungus's Avatar
Too bad Hmotors never has USDM GSR or ITR motors...no good to us in CA.
fm
Old Aug 14, 2009 | 10:45 PM
sayyoooon's Avatar
if you live in cali, i'd take the usdm, jdm you're gonna be screwed if you're pulled over.
Old Aug 14, 2009 | 10:48 PM
98civdx's Avatar
Master Detailer
1200 is alot of money to have hanging there...
just because he says it burns noithing means noithing.
i wouldnt do it, simply because for a bit more you could have a engine has under 45k and runs great. its dirty as hell and doesnt look like he took good care of it.
Old Aug 15, 2009 | 01:34 AM
bluebomber's Avatar
Information Leafblower
I bought a legit 95 B18C1 for my 95 EJ1 for 1800. It didn't include the axles or intake, but came with ECU half shaft, transmission, longblock, all sensors, new timing belt, new water pump, and header. It had 77k on it, so 2k is a good deal IMO for a legal swap that you can drop in your car and pass CA B.A.R. and smog.
I still rebuilt it top-to-bottom with all new internals because I wanted a new engine, but if that one runs okay, you can just do basic freshening of the seals and things like timing belt and water pump, and run it until you can afford to get it built.
I'd offer the guy 1700 and see what he says. I wouldn't pay more than 2K.
Old Aug 15, 2009 | 02:02 AM
davenport517's Avatar
lol i paid like $400 for a complete gsr swap cus the poor guy didnt realise what he had. hence that seems mucho $$$ to me
