quick way to check injectors?
Old Aug 14, 2009 | 07:42 PM
crxnonvtec's Avatar
Default quick way to check injectors?
whats the easiest way to see if injectors are firing??
Old Aug 14, 2009 | 08:15 PM
dacrxguy's Avatar
Default Re: quick way to check injectors?
noid lights
if not get a oscilloscope doctor ear thing and put the end of it againgts injector you should hear them clicking
Old Aug 15, 2009 | 06:16 AM
crxnonvtec's Avatar
wouldnt that just tell me if theyre gettin power ??? how would I know if theyre clogged would they still click?
Old Aug 15, 2009 | 07:39 AM
dacrxguy's Avatar
you said how to check if the are firing not if they are clogged or leaking that test is a bit more complicate
Old Aug 15, 2009 | 07:57 AM
crxnonvtec's Avatar
nevermind Ill figure this one out myself like all the other stuff
Old Aug 15, 2009 | 08:15 AM
dacrxguy's Avatar
quick rundown i dont have time right nao
presurize system
make an injector fire
nect injector
so on
they should alll have the same amount of pressure drop ont to low cloged to high leaking
Old Aug 15, 2009 | 08:25 AM
tek_civic's Avatar
Take them out and clean them. It takes 5 minutes and you dont have to give attitude cause no one will hold your hand.
better yet, just pull the fuel rail with the injectors still on em. tape them in. and have someone try to start your car. You might need the light from a candle to help see the fuel better
Old Aug 15, 2009 | 08:41 AM
crxnonvtec's Avatar
no its not because i want someone to hold my hand...I wanted help like forums used for...but all you get is people guessing......it seems very few seem to remember when they needed help and now the sit on their thrones like jackasses spitting out dumb comments about candles and saying "search" fifty times because they know how to bolt in some hasport mounts and plug in a rywire harness(by the way most of the time you search a problem on this sight you get alot of topics but all people say in them is "search" is that ironic or what?)
Old Aug 15, 2009 | 04:58 PM
tek_civic's Avatar
crxguy did a great job of helping. the problem wasnt really the answer he gave, but the question you asked.
Even when you re-worded your question he gave a good answer. Maybe a little rough to understand. but good answer none the less.
About the only thing better would be if someone came and held your hand.
Old Aug 15, 2009 | 06:01 PM
dacrxguy's Avatar
Im trying to help you but you are pushing it i woke up took a quick look at my pm's and left had breakfast and went to work i do not like being late to work.
Old Aug 16, 2009 | 06:31 AM
crxnonvtec's Avatar
well then i apologize but im so sick of this car not running plus usually when I get on here Im already pissed about the car...i found out the injectors are firing but only for the initial start all 4 will fire evenly then no more if I crank it for a while the tdc code8 pops up but only when I cranked it for a while other then that it doesnt appear
Old Aug 16, 2009 | 11:00 AM
tek_civic's Avatar
Are you sure your main relay is in proper order?
Old Aug 16, 2009 | 12:16 PM
crxnonvtec's Avatar
i ran power and checked for continuity between the points all 3 checked out ok on both relays I got
Old Aug 16, 2009 | 03:27 PM
lunalink's Avatar
^ douchbag!
Old Aug 17, 2009 | 07:42 AM
crxnonvtec's Avatar
Icon2 Re: quick way to check injectors?
theres an e in douche bag and i dont think its one word but thanks for the help....i guessed I reached the limits of this website when I get random comments like that...
Old Aug 17, 2009 | 01:51 PM
Perfectionist's Avatar
You mention a TDC code 8. The ECU looks for a signal from that sensor to continue delivering power to the injectors via the main relay. (Fuel pump is also controled in this manner). I would correct the situation causing the code 8 and go from there. Good luck.
Old Aug 17, 2009 | 02:12 PM
Hndbst's Avatar
Code 8 is a dist malfunction...get a known good dist and start car up it should correct your problem...
nihad
Feb 23, 2008 03:58 AM
eg_gsr11
Jun 16, 2006 04:35 AM
rtpassini
Nov 16, 2004 07:40 PM
StolenTeg
Oct 17, 2004 11:14 AM
EGHatchy
Jul 14, 2002 03:30 PM
