ls swap into 88std hatch, running rich,backfiring,sputtering HELP!
Old Aug 14, 2009 | 03:31 PM
GroundZer0 336's Avatar
Default ls swap into 88std hatch, running rich,backfiring,sputtering HELP!
well i did the mpfi conv. with a monotech harness and used my ls ecu and some other stuff from my crx that had an ls. everything was running pretty good except it took a while to start and ran really rich. today my map code came on so i put the one from my crx on there and no more code. now its just sputtering and running rich and backfiring flames like crazy even at idle. what should i check? im not getting any codes. oh, im also running a walbro 255 pump and a b&m fpr, which i havnt touched since i took it off the crx.if it would make a dif.
Old Aug 14, 2009 | 09:12 PM
enigma2446's Avatar
Default Re: ls swap into 88std hatch, running rich,backfiring,sputtering HELP!
this might be a dumb question but is ur fireing order not right also timeing...where does it idle at.....
Old Aug 15, 2009 | 06:18 AM
dephtone's Avatar
Run the stock FPR and make sure that isn't what is causing your issue. Also which ECU are you running? I am assuming the PR4?
Old Aug 15, 2009 | 05:04 PM
yeah its a stock ls pr4. i checked the firing order and it was right how i had it, thats one of the first things i thought of. i was going to put my stock fpr on tomorrow and see what happens. and also my other iacv becuase its idling like its sticking or messed up. dont know where its idling, i dont have any gauges or anything hooked up, except a water temp so i dont let it over heat messing with it haha. sounds like about 1.5 to 2k, then when i plug the hole in the tb for the iacv it seems to calm down and idle normally but still backfires. im thinking about just hooking up my wideband and seeing what my ar is, sincei have no clue what my fpr is adjusted to...
Old Aug 16, 2009 | 07:48 PM
well i cleaned and checked my iacv after putting my other one on that ended up being bad. put it back on, cranked it up w/ it unplugged and ran like it had been, then i plugged up the iacv and started idling high, id say about 2.5 or 3k then went back down and ran like complete **** and bogs when i hit the throttle. anybody know how to correctly adjust the iacv? would the fitv have anything to do with it, i forgot to bypass it when i hooked everything up and hooked it back up, its prob bad, i had it bypassed for like 2 years.
Old Aug 16, 2009 | 07:53 PM
oh and i cant find my stock fpr, tried to get my friend w/ a b16 4dr ef to come over and let me steal his but he didnt show, sooo...tomorrow is another day. but ill be trying to finish my downpipe and wastegate piping so. i just want this thing to run right.
Old Aug 17, 2009 | 06:39 AM
dephtone's Avatar
IACV doesn't really need calibrated, you just clean out the little screen. The FITV valve is if you have surging idle etc.
Are you using bigger injectors? As you said something about making the downpipe and wastegate? If so what size?
Old Aug 17, 2009 | 09:18 AM
running stock injectors for now, trying to find some dsm 550's. im just trying to get it running n/a w/ this b16 exhaust mani before i put my turbo stuff on there. making a 3 inch downpipe and relocating the wastegate cuz it hits the hood, stupid ebay log manifold haha. ill bypasst the fitv tomorrow and see if that helps
Rob91DA
Engine Management and Tuning
Dec 6, 2008 07:26 PM
londoncivic
Feb 1, 2008 12:20 PM
supracrx
Oct 29, 2006 09:58 PM
v-tecgoswahn
Oct 18, 2005 10:12 PM
redlseg
12
Aug 12, 2005 04:44 AM
