Suspension & Brakes Theory, alignment, spring rates....
Suspension Package Opinions
Old Aug 14, 2009 | 02:52 AM
BiG ChOr!Zo's Avatar
Default Suspension Package Opinions
Well im finally moving on to purchasing my front end suspension setup but need to know which one I should decide on...I have narrowed it down to the following three choices since im looking to purchase lifetime warranty parts and not cheap ebay garbage...I am also going to get a Firestone lifetime wheel alignment just in case anything breaks down...Hopefully someone out there has experience with the other two choices listed beside OEM since they want a arm and a leg
I have already researched Napa,Kragen,Autozone,Rock,Majestic Honda,Honda Parts Unlimited and various Honda Dealers and they are still way to overpriced...If anybody else out there gots a hook up for the lifetime warranty parts listed below please don't hesitate to let me know
Honda Dealer (OEM)
$196.84x2-Upper Control Arms
$85.59x2-Lower Ball Joints
$81.38x2-Outer Tie Rod Ends
$76.15x2-Inner Tie Rods
$879.92 Total
Pep Boys (Pro Steer)
$74.99x2-Upper Control Arms
$27.99x2-Lower Ball Joints
$33.00x2-Outer Tie Rod Ends
$31.99x2-Inner Tie Rods
$335.94 Total
Carquest (Moog)
$87.48x2-Upper Control Arms
$37.99x2-Lower Ball Joints
$47.99x2-Outer Tie Rod Ends
$43.99x2-Inner Tie Rods
$434.90 Total
Old Aug 14, 2009 | 03:41 AM
jloehlein's Avatar
Default Re: Suspension Package Opinions
Can't go wrong with Moog. What car is it for?
Old Aug 14, 2009 | 01:22 PM
1991 Honda Civic LX
Old Aug 14, 2009 | 06:15 PM
jloehlein's Avatar
You sure you looked at Majestic Honda? I show their price for the outer tie rods to be $45.26ea and the inners to be $42.36ea (see here). That's cheaper than the Moog stuff, and personally I would rather use the Honda parts for the same price.
Edit - Found the rest of your parts. $110 for each arm and $48 for each ball joint. Why are you replacing all of this stuff?
Old Aug 14, 2009 | 06:36 PM
my suspension is trashed...all ball joints are ripped and need to be replaced but the car still drives good even after 2 years...im swapping out the whole front suspension including the items listed above,power rack and pinion to manual rack and axles...the motor is getting replaced with a zc sohc motor...!!!
Old Aug 14, 2009 | 06:48 PM
.Manny.'s Avatar
Touching My Member
Very nice! It will literally be the best thing you have ever done!
Moog is pretty good from what I've heard on here, sorry no personal experience.
Old Aug 14, 2009 | 07:07 PM
that's what i have been hearing about moog too...i just want sometime dependable with a warranty and there are too many choices out there...i still want to find out how that pro steer pep boys suspension is since they got a lifetime warranty as well...!!!
Old Aug 14, 2009 | 08:52 PM
racebum's Avatar
moog or oem honda are both solid choices. as far as the arms go. i'm on the energy suspension bushings and have nothing bad to say. much cheaper. also more firm. however, i'm not sure they will live as long as oem.
Old Aug 14, 2009 | 09:05 PM
We'll I went on Rock auto and added the parts on a checkout screen just to see how much it would be...All the parts are Moog except the upper control arms which are Dorman (made in USA) and everything has a lifetime warranty...Any suggestions on if its a good deal or not...!!!
Moog
$38.79x2-Outer tie rod ends
$35.79x2-Inner tie rods
$30.79x2-Lower ball joints
Dorman
$53.79x2-Upper LCA's with Ball Joints
$339.67 Shipped
Limited Lifetime Warranty on all parts...!!!
Old Aug 14, 2009 | 09:08 PM
racebum's Avatar
no exp with dorman, if you're getting the arms for the upper ball joints. spending a little more for oem or researching dorman might be worth doing. everything else is great. to me moog=oem, basially the same quality.
Old Aug 14, 2009 | 09:22 PM
here's a link to Dorman and their control arms...it looks like they are made in USA and they are located in Pennsylvania...!!!
https://www.dormanproducts.com/cgi-b...rid=0x003a9cf5
Old Aug 15, 2009 | 04:47 AM
jloehlein's Avatar
Cool. Those prices from Rock Auto seem pretty good on the Moog stuff. I would stay away from the Pep Boys Pro-Steer crap. It would probably work fine, but it's not really much cheaper so you might as well go with the stuff of known quality.
Where are you getting the manual rack from? Do you know if it has the same ratio? I replaced the manual rack in my EG with a power one from an Integra and just looped the lines. The Integra rack had a quicker ratio and makes driving easier. I guess what I'm getting at is if you want manual steering, make sure you aren't getting a slower rack...if so, you can always just loop the lines on your power rack and remove the PS pump from the motor.
Old Aug 15, 2009 | 10:57 AM
racebum's Avatar
hmm, so they are putting new bushings and ball joints in an oe arm. as long as the joint is good they are worth getting. the bushings are easy to replace. the fact that they are american does make a guy sleep better than being from china. the rock auto order looks good. i'd stay with oem or moog for the other parts which is what it sounds like you plan to do also.
Old Aug 15, 2009 | 02:43 PM
i got the 88-91 manual rack & pinion on a trade from craigslist but it needs to be rebuilt...i currently have power steering in my ed3 but figured that my rack and pinion is getting hard to turn anyways and that it would be more cheaper to go the manual route...there's a couple pics of the rack below that i picked up on...!!!
i don't know about the company dorman itself but researched them and they are in the USA and a lot cheaper in price then other brands...They also come with a lifetime warranty as Moog so I fugured why not give it a try...I would buy OEM but have read some really good positive reviews on the Moog stuff and it is way cheaper in price then OEM which also only has a 12 month warranty unlike the Moog lifetime warranty...!!!
91akira
Jun 18, 2019 08:29 PM
HondaGuy2020
Honda CR-V & Element
Oct 22, 2018 08:31 AM
1989CivicSi
Suspension & Brakes
Jun 20, 2010 12:30 AM
PatrickGSR94
Jul 9, 2007 08:26 PM
Yog8511
Mar 17, 2007 07:33 PM
