ac and power steering in my civic.
Old Aug 13, 2009 | 11:43 PM
young geezer's Avatar
Default ac and power steering in my civic.
so i am going to put a 97 gsr motor in my 93 civic ex. right now i have ac and powering steering. and the gsr motor i am getting has ac condensor already on the motor. the question i have is can i use my oem civic ac hose on the gsr AC condensor? or will my civic ex AC condensor bolts right on the GSR motor.
Old Aug 14, 2009 | 03:58 AM
Anon51's Avatar
Default Re: ac and power steering in my civic.
i can't remember if you have to change the a/c brakcet or not for your car. but if you do its either the delsol a/c bracket or crv a/c bracket. i went and got the crv a/c bracket from a local junk yard for 20 bucks.
98 CivDx w/ GSR
DX A/C Compressor
Old Aug 14, 2009 | 04:49 AM
civicgsr's Avatar
Okay, the part on the engine is a compressor. The condensor is the part that looks like a radiator. You can't use the GSR's compressor as the fittings line up differently. You would either have to have custom lines made or covert to the integra's condensor and radiator setup. Not worth it.
I never thought about a CRV mount but if it is the same as the one use in the Del Sol VTEC, then it will work. If your AC is currently working, don't mess with it You can do the swap without removing the compressor (I've done every one of my swaps this way with no issues).
However, you do need to use the PS pump from the GSR engine. The Civic's lines will mate with it perfectly.
Old Aug 14, 2009 | 08:41 AM
alright so you are saying if i wanna swap out the engine, just unboltthe compressor from the motor(single cam) so i dont have to refill? and get a crv or del sol vtec bracket to connect the single cam compressor back on the gsr block?
Old Aug 14, 2009 | 09:10 AM
civicgsr's Avatar
Yes.
Use a wire coat hanger or bungee cord to hange the compressor from the core support. It makes things a little tighter, but it beats having to recharge your AC!
Old Aug 14, 2009 | 09:11 AM
alright. thanks alot bro. much appreciated.
raidacaipo
12
Jul 11, 2008 06:57 PM
rezneffix
May 16, 2007 09:54 PM
marc-111
Aug 24, 2005 12:47 PM
Turbotype
Dec 2, 2004 03:02 PM
