Installing Glass Break Sensor. Splice wire???
Old Aug 13, 2009 | 11:12 PM
bopbop93030's Avatar
Default Installing Glass Break Sensor. Splice wire???
Ok. My Viper 350 Responder don't have an extra 4 pin port in it. I have a proximity sensor that is hook up to that single 4 pin port.
Do I need to splice the 4 pin wire that the proximity sensor is using and tap that to use the Glass Break sensor? And do I need to install a diode in between the proximity and GB sensor for this to work or will this work as it is.
Single 4 pin connector having 2 installed devices. Proximity and Glass Break sensor.
Hopefully this make sense.
Thanks!
Old Aug 14, 2009 | 06:15 AM
fcm's Avatar
fcm
Old Fart
Default Re: Installing Glass Break Sensor. Splice wire???
Yes, you can just parallel, [splice] the trigger lead from the GB sensor to the trigger lead, [full trigger] of the prox sensor, a diode must be installed on both trigger leads. 94
RVMIRXZem1
Nov 11, 2018 08:15 PM
stephen_civic98
Audio / Security / Video
Mar 19, 2007 02:37 PM
dxhatch93
Mar 25, 2006 02:22 PM
743power
Jan 23, 2006 06:11 PM
MooreBoost
10
Apr 7, 2004 08:24 PM
