gsr dizzy on b16 head
if you dont know let me know what year and model your engine to your car is. otherwise if you want to use the 95gsr TEC distributor on a 95 del sol head (b16A3) that will work.
ANY OBD-1 or newer "B" series VTEC distributor. They all bolt up the same... B16A, B16B, GSR or ITR, but they will have different style plugs depending on year and application. The B16A has a smaller diameter housing, and thus, uses a slightly smaller cap and rotor button. Internally, they are the same. Coils are interchangeable. The housing number on an ORIGINAL distributor will be stamped on the edge of the mounting flange near the top bolt facing the front of the car. It is expressed as a 5 digit code... TD-XXU. The "XX" varies by application. The TD-44U would be an OBD-1 B16A distributor.
Thanks JRcivic for your help.
crxfreak1117
Apr 18, 2007 10:40 AM
TurboEM1
Mar 23, 2007 08:16 AM
incognitoracerr
Oct 26, 2003 09:45 PM
