Looking for vr-4 galant
I know this is all Honda's most of the time for sale but i have seen some vr-4 galant's on here also and i am looking for one around $4,000 lmk or if anyone has seen one for sale send me a link Thanks
1992 Mitsubishi Galant VR4 #808/1000
$5,500
NO LOW BALLERS PLEASE. thank you![/B]
I am open for offers.
***UPDATED***
I am the 3rd owner. Second owner rebuilt the engine at 40,000 miles. The car drives extremely great for a DD. It has not failed on me once and it actually gets decent mpg on road trips. These cars are getting more rare every day. This is also a RARE 92 Model that comes with a fully functional sunroof. I also have rain guards that are super rare to obtain for this car. I’m giving away a lot of things I was going to do the car, but I have no time to do it. Stuff I’m letting go with it are th 2G MAS, KYB AGX struts with H&R springs, 3 92’ Galant VR4 rims(2 with really good tires on them still). This car is flawless. It’s an awesome beast to drive around but I’m selling it because there are things in life that I must accomplish first before this. My plan was to FULLY restore it but time is not with me and can’t do so.
MOD LIST:- The cylinder head was ported on both intake and exhaust sides, upgraded valve guides and bigger lifters. Right now, it has about 75,000 miles on the engine.
- Bored .020 over
- All new rings, pistons, and bearings
- Ported 2g manifold with Mitsu 4-layer exhaust manifold gasket
- Ported o2 housing
- Big 16g turbo, ported exhaust housing. I had 92Talon/TkrPerformance(Mark) fix and re-thread a broken bolt on the exhaust side with a new 7cm gasket. So there are NO exhaust leaks or broken bolts holding the turbo to the manifold.
- 3 inch exhaust system with Apexi muffler
- HKS Super Megaflow intake (I will include the 2g MAS)
- MAP Intercooler Pipings with FMIC
- 550 fuel injectors
- Walbro 190 (I will include the 255)
TRANSMISSION:
Rebuilt at 100,000 miles at Mitsu Dealer
- All brass syncros used
- 1g short shifter
- ACT 2100 clutch and disc
NOTE(Updated 5-31): I changed the Tranny Fluid (Royal Purple) and replaced the 2 front axles. It shifts much much better now!
ELECTRONICS:
- Technomotive Stage 3 Eprom ECU Mod: It has the stutterbox, injector read, O2 read, battery voltage read, and a variable RPM launch; all measured and controlled through the factory dash
- SAFC (owner before me had it tuned by LSE) I’ve had it slightly tuned to compensate the FMIC and injectors.
- Apexi Electronic turbo timer- doesn’t work but is fixable I just haven’t had the time to.
- Greddy Profec-B Electronic Boost Controller
- Boost Gauge
- Installed HID 8K
- Alpine Deck with controller
- Stock stereo system and it’s clear!
- K40 radar
INTERIOR:
- small leather cracks, nothing big to be noticed
- black leather interior
THE BAD:
- Only rust spots are on Driver Rear Door and Driver Fender.
- The ABS motor is toasted and you’ll need a new one.
- 3rd gear will grind if you shift fast
JULY-26 UPDATE: Rear Caliper is sticking, I will have it fixed quite soon!
THE GOOD:
- NO LEAKS! The car doesn’t leak at all!!
- Everything in the car works and functions. The AWS, a/c, p/s, and cruise control all work and function perfectly.
- I will include KYB AGX struts with H&R Springs that will lower the car.
- I will add the 16” Enkei RS5 rims w/ 225-50-16 BFGoodrich g-Force T/A KD SSS
- I always used AMSOIL 10W-30 since I’ve owned it.
- Just replaced the Alternator and it starts up quickly!
I will send the VIN to a moderator if needed
__________________
-Cesium Liquid Injected with 1000cc secondary fuel injectors-Twin GT28s with quad 44mm external wastegated-Rubidium mixed Cesium fuel cells and triple fuel pumps-
$5,500
***UPDATED***
- Bored .020 over
- Ported o2 housing
TRANSMISSION:
- 1g short shifter
ELECTRONICS:
- Boost Gauge
- Installed HID 8K
- K40 radar
INTERIOR:
THE BAD:
THE GOOD:
__________________
90Rexx
Classic Hondas
Aug 11, 2011 07:05 PM
