electrical problem
Old Aug 13, 2009 | 04:25 PM
linnhatch's Avatar
Default electrical problem
1991 civic si. Gauge cluster lights the corner markers and the bumper lights
will not work. The blinkers will work in the bumper but no parking lights and
nothing in the corners. I tried to different dimmer switches and a diff cluster.
Any ideas would be helpful. thanks
Old Aug 13, 2009 | 04:29 PM
BiG ChOr!Zo's Avatar
Default Re: electrical problem
check fuses under your dash and in the engine bay...!!!
Old Aug 13, 2009 | 04:46 PM
linnhatch's Avatar
i checked. all fuses seem to be fine. Is there a ground that would make these things not work
Old Aug 13, 2009 | 05:21 PM
xpwex's Avatar
When you say gauge light not working do you mean like brake warning lights, oil pressure, the blinker lights etc or just the lights the illuminate the cluster?
I was looking at my Honda service manual and found there is one ground that ties all these well 2 grounds G301 and G401. This all gets power from the No. 1 fuse 10A....and what powers that is the (BLK/YEL wire) IG1 switch in your ignition....
Hope it helps
Old Aug 13, 2009 | 05:49 PM
linnhatch's Avatar
the illuminate lights in the cluster. what would you do to fix it?
Old Aug 14, 2009 | 09:26 PM
enigma2446's Avatar
are you sure u checked all the fuses in the engine bay and under the dash.....honda likes to piggy back there wiring on multipul fuses if all fuses are good then u might be grounding out somewhere...is the illumination light to ur heater/ac housing out to?
Old Aug 21, 2009 | 07:36 PM
linnhatch's Avatar
yeah, all the lights are out, and all fuses are good
andrew.eg8
11
Sep 22, 2016 05:02 AM
j3wman
Jan 9, 2012 10:34 AM
mynameisMUDD
12
Jan 16, 2010 02:10 PM
2f2fLOL
May 23, 2007 09:50 AM
philkehn
Nov 5, 2006 08:39 PM
