Plugs covered in Oil.....white smoke????
The car has been running a little rough - and since this is my daily driver I wanted it to be in prime running condition for winter! I pulled the plugs and they were covered in oil...!!???!!! Also when I accelarate hard the exhaust turns to whitish smoke!?!?!?! Any suggestions?
I had that problem with two of my plugs. Turns out the round gaskets that go between the spark plug slot on the head and the valve cover were gone. Check those. The white smoke does sound like a head gasket though.
this is happening to my friends sr20det motor, the rubber rings that seal the spark plugs are shot to **** and they are on backorder since they have to come from japan. This is why his plugs have oil on them and can lead to smoking. But another reason he has smoking problem is due to his oil seal on the turbo going bad i believe, i assume you are running turbo? a faulty oil seal on the turbo wont give you oil on the plugs though... replace the rubber rings.
EF9 JAMS!!!
Jan 5, 2006 12:43 PM
chirp2hrd
Jan 24, 2003 08:19 AM
