jdm b18c wiring harnesses? help
i just put the car over the engine and ready to bolt in the motor mounts (into my 93 eh2) and i noticed that the shock tower harnesses are backwards, as in the ones for the driver side are on the passenger side, i imagine its because the engine came out of a right hand drive car Can i just unhook them from the engine or aren't they long enough?
It never makes sense to try to use a RHD harness in a LHD car. Reuse your original harness, you will have to cut and lengthen some connectors to reach, You will also need to add in the wiring for vtec, as well as the knock sensor and IABs if you are using an ECU that recognizes them.
thanks for the reply, i talked to steve at HMO and he said the same thing, but my old harness from my d15 is so old and bad im going to buy a gsr harness. I didnt even think of the whole rhd thing when i was putting it in.
93EssEYE
Jun 5, 2011 08:19 PM
