What turbo kit is better? FMAX or DRAG
Old Aug 25, 2002 | 01:49 PM
billk2k's Avatar
Default What turbo kit is better? FMAX or DRAG
I have a JDM H22a in my 95 Accord and was wondering what complete kit was best to buy, FMAX or DRAG? I have seen some websites that put DRAG kits down, but what is the actual truth about them. Thanks!
Old Aug 25, 2002 | 01:51 PM
AmginE's Avatar
Default Re: What turbo kit is better? FMAX or DRAG (billk2k)
c. custom
Old Aug 25, 2002 | 02:25 PM
Brandon's Avatar
Life is Suffering
If you want a turbo, you will have to go custom since the F-MAX and DRAG kits are only for the F22 and will not fit the H22A.
Old Aug 25, 2002 | 02:26 PM
niedejb's Avatar
Default Re: What turbo kit is better? FMAX or DRAG (AmginE)
I like fmax. Fit perfect. Came with an MSD boost timing module (retards under boost). Manifold already had a port for exhaust gas temperature probe.
Some people dont like the two intake injectors. I didnt use em. I already had a vafc and 500cc injectors so for another $100 I got an FMU.
Old Aug 25, 2002 | 07:18 PM
WhoNeedsVtec's Avatar
Default Re: What turbo kit is better? FMAX or DRAG (niedejb)
greddy relaced a turbo kit for the h22, dont know if anyone is running it. and i know they make a f-max kit for an h22, there was one in honda tuning running an f-max kit. consided of their exhuast manifold, piping, but turbonetics t3/t4 hybrid super 60 tuboand deltagate wastagte, says it daily driven at 12 psi. used fmax 'magical' head gasket.
Old Aug 25, 2002 | 08:46 PM
FastechAccord's Avatar
Drag just came out with the new Gen IV kit for preludes and accords. Drag uses the same components as fmax except for the fuel setups. Personally I dont like the fuel setup on either kit. Drag also makes kits for accords with H22 swaps. I would buy the drag kit and either use the greddy emanage or, if you just want to run a max of 11 psi, you can use the VAFC hack.
Also, you do know that H22s dont last very long under boost. They really need to be built to be reliable under boost, unlike the F22.
Old Aug 26, 2002 | 05:37 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: What turbo kit is better? FMAX or DRAG (EvoAccord)
I talked to someone in another forum who said he had a F22 with a turbo and when he switched to H22 all he had to do was get a H22 turbo manifold and it all hooked up fine.
What is the web site for DRAG?
Old Aug 26, 2002 | 06:03 AM
Brandon's Avatar
Life is Suffering
Default Re: What turbo kit is better? FMAX or DRAG (TouringAccord)
DRAG does not have a website, a telephone number or even an adress for us to contact.
Old Aug 26, 2002 | 06:32 AM
H-T Order of Merit
Default Re: What turbo kit is better? FMAX or DRAG (F22turbo)
Ok, well......is there a website that sells DRAG kits and has info on DRAG kits?
Old Aug 26, 2002 | 08:00 AM
billk2k's Avatar
How long to h22's usually last under boost? If you only had the h22 at a set PSI of around 8 then shouldnt the engine last just as long as a boosted f22 with the same PSI? What would have to be done to the engine in order to handle the boost properly?
Old Aug 26, 2002 | 08:27 AM
For Drag kits check out overboost.com or importparts.com. Importparts.com is where i got my kit and they have good customer service. Ask for Ben, he will give you a rock bottom price and you can even delete parts of the kit to lower the price. BTW, people knock drag kits b/c they have no website or phone number. Who do you call if you turbo, wastgate, or fmu ***** up? If you call turbonetics they will replace your turbo or wastegate and vortech will do the same. What else on turbo kit could malfunction? There are really only a few parts that could break.
Old Aug 26, 2002 | 09:24 AM
Luv2roost's Avatar
I'll sell you my Drag 4 kit. Brand new with zero miles on it, and you won't have to wait six to eight weeks to get it. H22A accord hybrid kit.
1.8turbolsvtec
Jan 31, 2004 07:28 PM
kevinm1981
Dec 18, 2002 07:28 PM
Mattie
Sep 26, 2002 10:21 PM
hondaZvic
Sep 20, 2002 11:14 AM
TruePlayaz114
Mar 25, 2002 12:24 PM
