b series swap in HF..why so much more pain?
so exactly what needs to be done to drop b series motors in HF crx's? I'm thinking about selilng my si and buy me a HF or DX (ac and i hate sunroof). thanks in advance!
Jeff-
Jeff-
HF has basically the same wiring as an Si, that isnt a problem. THe only real pain, is that the spindles have to be swapeed out since the HF uses a different spline on the outer axle joint. DX is the real pain because it has to be wired to use MPFI from DPFI
While you are at get 90-91 ex sedan spindals and get 10.4" brakes, or add 92-96 prelude vtec rotors and 91-94 accord wagon calipiers and get 11.1" brakes. That's what I did.
si and hf wiring harnesses are the same
if u are using a nonvtec u will need 90-91 integra distributer
si steering knuckles
90-93 non vtec axles they made a gsr in 92-93 so dont get those
motor mount kit
90-93 non vtec upper lower coolant hoses
either buy or make your shift linkage if u wanna buy it call hasport
do your self a favor and try to find an A1 tranny
my crx has 81.5 endyn pistons
stock rods, cams, head intake and a hedder
i ran a 12.37@109 in the 1/4 7.97@91 in the 1/8
non vtec is the way to go if u are on a buget
good luck man
motor mount kit
good luck man
i have a 89 dx with a b17 swap(93gsr) i used the same axles and spindles that came with the gsr. why only non-vtec axles? mine work fine.
just get a hf and get ex/si/dx knuckles...other than that...you'll need everything you normally need for a bseries swap into a si
HaHaHa jeff, just save yourself the trouble and get an Si. Why an HF? Wanna save on weight?
(1)weight
(2)hate sunroof
(3)i want a black crx now
(4)ac
Jeff-
any websites on how to do this?
Jeff-
Jeff-
Sorry, had to ***** our my web site a little bit
[Modified by Speed PHreak, 3:54 PM 8/26/2002]
I'll echo some things said here:
Get an HF.
I work at a shop that does only Hondas, and we've done plenty of swaps into the 1988-1991 Civics and CRXs.
It is so much easier to swap front knucles onto an HF than it would be to rewire a STD or DX from DPFI to MPFI.
I have a co-worker who did this in his car, and he took a good while doing it. While it looks factory now and all, it did take him some time and he is very good with car electricals.
I would not want to undertake the wiring from DPFI to MPFI - that's just me I guess, but the front knuckles are so easy to swap man.
Good luck, and by the way, that extra light-*** HF body can't hurt performance now, can it?
Get an HF.
I have si...but I want hf for the following reasons
(1)weight
(2)hate sunroof
(4)ac
Jeff-
(1)weight
(2)hate sunroof
(4)ac
Jeff-
(1)weight
(2)hate sunroof
(4)ac
Jeff-
You won't be able to keep A/C if you do HF and B16 together, I have this and you might be able to just be ready for one hell of a headake
(1)weight
(2)hate sunroof
(4)ac
Jeff-
Am I missing something here?
The guy at my work who did the STD to SiR wiring also did his own custom A/C bracket and his A/C blows 32 degrees on cylcle!
all I am saying is that I did this swap and I have no room for A/C and if I wanted to keep A/C I think it would be a bigger headake then what it was worth, also I don't know what you what to do with the car if it daily driven or auto x or show or all the above.
I am just saing that good luck with installing it and have fun.
the hf doesn have an ac button.. nor is insalled with the factory ac crap...
Once they rolled off the trucks and into the dealers though, many of them recieved the factory Honda A/C before customers ever laid eyes on them.
This is also true for all the 1992-1993 Civic hatches - even the Si.
I know this from working at various dealers and having a 1992 Si that wasn't equipped with A/C from the factory.
My 1992 CX still has the original A/C "block-off" button where the dealer never put Honda A/C in.
I wasn't trying to be an ***, but it looked like you meant that just the HF model would not support A/C.
back for you being a dumb *** and reply back w/o any sort of knowledge. I have a b16 in my 90 si and I *KNOW* it can be done w/ AC considering I can import the WHOLE EF8 clips if I want to.Headache? What's not headache when it comes to cars?
Jeff-
