changing injector harness.. obd2 to obd1
hi guys, im fitting some injectors to my ITR, the new injectors have obd1 style clips so i have to cut and solder them on, do the 2 wires have to go a certain way around when soldering them, or can they go either? thanks dan
when i did mine i just held the clips the same way and took the wire that was on the right and spliced it to the wire that was on the right. do you understand? and it worked out perfect for me.
