My AM GSR Died - Help Needed ASAP
Old Aug 12, 2009 | 10:50 PM
johnson_racing's Avatar
Default My AM GSR Died - Help Needed ASAP
Well, this evening I took the car around the block for an evening spin and a tragedy struck. I, un aware of this, mounted my autometer oil pressure sender unit on the back of my motor using a t-fitting. The fitting gave way and broke of leaving the tip stuck in the block. From what I seen so far, there is not external block damage. The car did not run long or hard when the leak was found. In fact, the car was shut down and towed home. I am not aware of how much oil was lost yet but its atleast a court and a half.
Events leading to this, I had the car dyno tuned yesterday after installing a brand new set of Skunk2 Pro 3+ cams. The car made an astonishing 208.4 whp w/ 140 ft/lb of tq. No leaks on the dyno.
So tell me honda-tech guys, where do I start?
Is the motor a total loss?
Old Aug 13, 2009 | 03:44 AM
dyingwish's Avatar
Default Re: My AM GSR Died - Help Needed ASAP
Were the T-fitting and adapters brass or aluminum? Did it make any noises at all? We need more useable info.
Old Aug 13, 2009 | 05:41 AM
robfrmny21's Avatar
208 hp on pro 3's i think you over cammed the motor, show pics of part your talking about. if you shut it off be4 you spun a bearing you should be fine
Old Aug 13, 2009 | 09:54 AM
[BLOCK]--[ADAPTER]--[T-FITTING]--[OIL PRESSURE UNIT]
The adapter broke. I drove the car for about a mile when I noticed something smelt not quite right. No noises or warning lights. I pulled over imediately and noticed an oil spot underneath the car, i shut the car off as soon as i saw the sport. I messed with the units on the back of the block and noticed they were loose feeling. I turned them as if I was going to tighten them and the whole unit fell off with out applying any force at all. The car has not ran since or anything.
The car made 190 whp with Crower Stg. 3 Cams. I switched to S2 Pro 3+ and got the 208.4. After tuning the car, we notice the valve lash was slightly off so we adjusted the valves after the dyno and seen noticable gains once more. We are pretty sure we have netted more hp but just aren't sure. I live in Kansas too so, 1300ft above see level, my car won't through down the numbers like those of you at sea level. Also, I ran out of injector when tuning so I am waiting for new injectors.
Old Aug 13, 2009 | 10:00 AM
06sik20z3's Avatar
has happened to me twice with a brass adapter i ditched the adapter and get a sandwich plate.
DDTECH's Avatar
how long was the car ran with oil missing..
I'd suggest removing the valvecover and see if the cams, rockers or anything of that nature is damage.. that would be the FIRST thing to show abuse.
The bottem end, has oil reguardless, the top end would show abuse first.. i'm pretty sure if you caught it as fast as you did, you should just change your oil, and crank it over by hand to see if you have anything of force against you, if not, you should be fine.
get a damn sandwich plate, your motor vibrates too much for a t-off.
Old Aug 13, 2009 | 10:17 AM
Top Ramen's Avatar
Agreed.
1) pull the valve cover to see if anything looks torn up
2) fix it right (sandwich plate)
If you stopped it quickly, you should be okay.
Old Aug 13, 2009 | 10:32 AM
namewasdallas's Avatar
id say fix what needs to be fixed, do a oil change and start it up listen for any weird sounds, but from the sound of what happend it seems as u pulled over quickly i wouldnt be to worried
Old Aug 13, 2009 | 01:44 PM
98civ's Avatar
who tuned your motor?
Old Aug 13, 2009 | 03:20 PM
DDTECH's Avatar
why would that matter?
Old Aug 13, 2009 | 04:03 PM
b19coupe's Avatar
Icon3 Re: My AM GSR Died - Help Needed ASAP
Always blame the tuner-the easy scapegoat.
No oil pressure? It was the tuner's fault.
Overheating? The tuner's fault.
Stereo stopped working? You guessed it, it was the tuner's fault.
Old Aug 13, 2009 | 04:11 PM
Combustion Contraption's Avatar
I dont understand why, for the life of me, people still run those TEE fittings instead of a damn sandwich plate. The sandwich plate's are just as easy to come by and only marginally more expensive.
Old Aug 13, 2009 | 07:13 PM
98civ's Avatar
i never said it was the tuners fault. i was just wondering were he got his car tuned, since we happen to both be from kansas.
Old Aug 13, 2009 | 07:14 PM
98civ's Avatar
read post below
Old Aug 13, 2009 | 07:20 PM
BigBlock22's Avatar
tuned sandwich without a plate???
Old Aug 13, 2009 | 07:26 PM
lol...nice guys. Well, I drained the oil, still had about a quart in a half. Check under the valve cover, everything was fine, no heat abuse. I put new oil in it and everything seems to be fine. No knocks or anything. thank goodness. But thanks for the help guys.
I had Ray at Fusionworks tune my car. He is a great guy to do business with. I have to take the car to the shop next week, doing a little custom work. Hoping to take the car to IFO in KC, Sept. 6th and try my all motor skills.
Hippycrippler56
Oct 25, 2018 09:20 PM
vtechjunkie
Jul 12, 2012 04:55 PM
spidy3
Sep 7, 2009 06:54 AM
1sikhatch
Jul 22, 2009 01:29 AM
