control arm problem
ok i have a 92 dx hatch lowerd on h&r race springs with kyb g2 struts and i am eating through pass control arm bushings its only the front inner how do i fix this from happening its like every 3 months it needs replacing what could be causing this
some signs:
-the car "wanders" really bad on the highway, uneven pavement... even when you're holding the steering wheel still
-the car likes to pull different directions and do odd stuff when you go over roads with ruts
-when turning into a corner, the car first turns normal for a few seconds, then suddenly pulls farther toward the direction your turning
-if you can grab the wheel and pull it away from the car and see the control arm moving... if the bushings are stiff enough this should not be happening
-severe front tire wear, even though the alignment seems perfectly fine
some signs:
fryman
14
Jan 30, 2013 08:13 PM
