can you interchange wastegate springs?
Old Aug 12, 2009 | 08:18 PM
1DayIllBFast's Avatar
Default can you interchange wastegate springs?
I have a 38mm tial wastegate with a 5.80psi spring and my friend gave me a 38mm turbonetics 7.25psi watsegate spring. my question is can i use his spring in my wastegate? i would think as long as both wastegates are 38mm i can do it.
Old Aug 12, 2009 | 08:35 PM
TheShodan's Avatar
Moderator
Default Re: can you interchange wastegate springs?
Perhaps, perhaps not. Tial springs interchangeable with one another. You may have to try to see if it works with Turbonetics. Most here typically don't interchange companies like that. Give it a shot and see.
Old Aug 12, 2009 | 08:45 PM
well i also made another post on if ill need a retune if i only add like 1.5psi? can you tell me if i will need one or not?
Old Aug 12, 2009 | 08:53 PM
TheShodan's Avatar
Moderator
that's difficult to answer. If you're tuned up to a certain point, anything above it MAY require some additional fuel, but that is determined by your tuner if whether or not he has set the mapping up to stay within an AFR above the point that you had before.
Old Aug 12, 2009 | 09:33 PM
ok well thanks i will ask him tomorrow.
To anyone else if you know for sure if the springs are interchangeable please let me know. Thanks
Old Aug 13, 2009 | 03:59 AM
jhammond_82's Avatar
Reject Papi
i know on my el'cheapo emusa brand wastegate, it says i can use tial or turbonetics springs. haven't installed it yet, so can't tell you for sure. but, springs are so cheap on ebay, why not just get a new one?
95boostedeg
Jul 11, 2011 05:27 AM
D15Bbigred
Jul 14, 2006 01:46 PM
Boost3d22
Dec 13, 2004 03:57 PM
SpdFrk
Jul 24, 2004 10:25 PM
