timing?
Old Aug 12, 2009 | 07:44 PM
jsteadman's Avatar
Default timing?
soo when i start up the car (96 accord 5 spd) it likes to like....rev itself.
it will do the whole rev to 2.5rpm then drop down after it starts and thats normal.....but then it does it over and over again...AAGGHHH and idk if its a timing issue or what....the autozone guy said the distributors on my car like to fall apart and stuff on the inside...any ideas?
Old Aug 12, 2009 | 07:59 PM
tdohcaccord's Avatar
Default Re: timing?
ok, this is a big issue. heres what to do and check. in this order too
check every single vacum line, dont look at them, check them,
pull off your intake(stock or aftermarket) and when its doing this plug one of the two holes you will find in the intake. if it goes away when either of them are pluged then its the idle air control valve or fast idle thermo valve.
i think the bottum hole is the fast idle thermo valve and thats a easy fix.
then let me know if any of those fix it, plus did you happen to replace any intake gasket recently?
Old Aug 12, 2009 | 08:00 PM
Default Re: timing?
oh and a dizzy going out will not cause your idle to do that. your engine is getting more air than normal then over comensates and cuts the idle, then goes back to normal where aire leaks again.
Old Aug 12, 2009 | 08:10 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: timing?
Not timing, common occurrence, usually very simple solution, do a search
Old Aug 12, 2009 | 08:44 PM
nus_dogg's Avatar
Default Re: timing?
Clean out your IACV and adjust the FITV located underneath the TB. There's a DIY in the FAQ section for Accords.
wesk18
Jul 25, 2011 06:35 PM
Swift9
May 29, 2006 06:49 PM
Zatzy
Apr 16, 2006 10:57 PM
sailor
Apr 18, 2003 06:36 AM
