zc engine rebuild time, have basic questions
ok so im going to get a rebuild kit here soon for my sohc zc, this is the one im getting, suggestions? http://cgi.ebay.com/ebaymotors/88-91...=p4506.c0.m245 ok so the real tech questions are, how do i measure my piston ring size that i will need. does it have to do with the bore? and if so how is it measured? also the main bearing set and rod bearing set size. thanks everyone
well from what ive learned the only big diffrence is the cam in the head. ive read that the internals are the same as the d16a6, anyone think the same?
Measure the size of the existing pistons. That is the right kit if you can figure out which pistons you need. You could always just go ahead and get the 75.5mm pistons and then have the block bored out even if they are 75mm pistons.
Chris
Chris
