NEED PERSONAL INSIGHT ON SUSPENSION
As the title states, im looking for personal experiences with both blox 1 pieces coils and omni power 1 piece coils, looking into buying a set for my coupe and am unsure of what to buy
before you buy any suspension part ask yourself
1. what do i need it for
2. what do i know about tuning a car or even doing suspension
3. what have i used in the past
4. what are others with the same car using and why.
you might change your mind about what you buy all togeather
what car, tire, ride height and intended use are the majority of your concern when doing upgrades
as far as higher rates go, some run stock koni yellows up to 600ish lb/in. personally i have 500lb fronts and 430lb rears with a strong rear sway. the shocks are cranked to firm and the rebound dampening isn't bad.
Don't forget that swapping spring rates changes the ride height (without adjusting the spring perch to a compensated height), which changes the toe, which will eat tires and can cause handling issues (depending on how bad and which direction they go).
true this. firestone has a lifetime alignment for $139, i suggest either buying this or learning how to set your own toe with stickers and a tape. only problem with the sticker method is that it takes some trial and error if you ever loose center of the wheel. it's also not as accurate as a real machine. you can get within 1/16th with a little fiddling though.
