stiff pedals. is there anything i can do?
Old Aug 12, 2009 | 04:56 PM
Dan S's Avatar
Default stiff pedals. is there anything i can do?
clutch, brake, and accel pedals are super stiff. is there any way i can tweak with them so theyre nice and soft?
Old Aug 12, 2009 | 04:58 PM
gilbert90605's Avatar
Default Re: stiff pedals. is there anything i can do?
softer springs for gas..
brake idk bleed the brakes?
clutch look down there and check out the springs
Old Aug 12, 2009 | 09:16 PM
Dan S's Avatar
my friend says to swap out the clutch fluid, will that work?
Old Aug 13, 2009 | 01:10 PM
did it just start happening?
or is that how you got it?
there is a spring attached to the pedal it might just be too strong cost like 2 dollars to get a softer one. just make sure its not too soft
my friends tell me my clutch is hard to push.
i just got use to it ..my leg did get sore one day ha ha.
check the spring first.
much easier than bleed since you will need help
Old Aug 13, 2009 | 07:32 PM
Dan S's Avatar
whereabouts are the springs located?
KillChris
May 14, 2015 12:59 PM
B_Swapped93
Nov 27, 2013 07:12 PM
einzelherz
Jan 24, 2013 06:24 AM
RedlineRex
Jan 31, 2005 12:49 PM
cjohnson_2
Nov 4, 2001 05:51 PM
