Question about the EP3 :)
Are the 2003 and 2004 front bumper and headlights the same?
i bought a Ep3 with slight damage and found a oem 2003 ep3 bumper forsale but wasnt sure if it would fit
thanks guys! back in the honda game!
No they are not the same but I would imagine they fit. Im not super knowledgable on this car yet I just got a few months ago but I would think they would I think the changes were just cosmetic between the 2 years
no its not the same. i think in order to put the 03 or o4 light on each other you would need a harness or something. there is a diy on ephatch on how to swap the head lights. i think the tail lights are a direct bolt up though.
The bumpers are the same its just the design of the headlight is different! If the bumper weren't the same we wouldn't be able to swap headlights with the 04-05 so easily!
Civic Si information
2002-2005
In 2002, the Civic Si received a complete redesign and returned to form as a hatchback. The body shape of this model was based on the "New Bullet-Form" concept, which aimed to create a more dynamic look and provide greater stability while traveling on highways or winding country roads. The interior layout also distinguished itself from other Civic Si generations with a dash-mounted shifter. Based on a platform manufactured at the Swindon plant in England, the hatchback was launched around the world in many different trims, most notably as the Civic Type R in Europe and Japan.
Shifting away from the B-series engine, the fifth generation Civic Si adopted the K-series K20A3 engine, which put down 160 hp (119 kW) at 6,500 RPM and 132 lb·ft (179 N·m) of torque at 5,000 rpm.[10] With a redline of 6,800 RPM, the Si distanced itself from the narrow, high-RPM powerband engine of its predecessor, and as a result saw a 20 percent increase in torque. Performance was relatively underwhelming compared to the competition; the switch to MacPherson struts from double-wishbone suspension resulted in less responsive handling, and a near-150 lb increase in weight to 2,744 lb contributed to slower acceleration than the lighter '99-'00 Si.[11] Much of the weight gain is attributed to the chassis' stouter structure when compared to the previous generation hatchback, with the '02 Si boasting an increase in torsional rigidity by 95 percent and a bending rigidity increase of 22 percent.[12]
With the increased chassis rigidity compensating for weight gain, the 5th-generation Civic Si saw roughly the same performance numbers as the previous generation Si, with 7.6 seconds to 60 mph and 15.8 seconds at the quarter mile. [13] Other factors adversely impacting performance included the lack of an LSD (limited slip differential) and having to shift into third gear to get to 60. First gear ends at about 30, second ends at 55, and third ends at 82 mph (132 km/h).
The '04-'05 models received minor revisions.[14] Cosmetic changes included revised headlight (dual bulb setup) and taillight designs, standard side skirts, and an option for a HFP. The suspension was updated with a change from 4 lug to 5 lug bolt pattern, a larger rear sway bar, and a change from the 15-inch wheels (195/60-15) to the 16-inch wheels (205/55-16). The interior received more silver accents in place of the chrome ones (the lock switch).[15]
The Honda chassis code for the Si and Type-R models is EP3. In Canada it is referred to as the Honda Civic SiR, and was discontinued in 2005.
Fifth generation Si
(EP3)
Production 2002-2005
Assembly Swindon, England
Body style(s) 3-door hatchback (EP)
Layout FF layout
Engine(s) 2.0L 160 hp (119 kW) I4
Transmission(s) 5-speed close-ratio manual
Wheelbase 101.2 in (256 cm)
Length 165.7 in (420.6 cm)
Width 66.7 in (167 cm)
Height 56.7 in (142 cm)
Curb weight 2,740 lbs
Fuel capacity 50 L (13.2 US gal)
2002-2005
Fifth generation Si
(EP3)
Layout FF layout
the soL that could
Sep 30, 2011 10:47 PM
