axle problem?
Old Aug 12, 2009 | 03:39 PM
BLU CIVIC's Avatar
Track Advocate
Default axle problem?
started while driving to work on monday. sitting at a light and it turns green an i get vibration from the drivers side like there were indentions in the road. didn't think nothing of it. i drive about another 10 miles and at another light. light turns green and the vibration is more noticeable and pulls a little to the left. don't think anything of it b/c i still think it's the road. i hear a metal noise and dismiss that as the car going past. few miles later at another light. well i take off from the light and vibration has grown increasingly noticeable and the metal noise is very audible. i'm thinking my wheel is going to fall off or something. i get to work and jack up the car. i spin the wheel w/ no sound coming from it and no play from the wheel bearing. later that when when my wife comes to pick me up she drives it around the parking deck and no sound at all coming from it. could it very well be my axle? the inner boot has been torn for over a year now. i'm getting new axles either way, but i want to know if the problem could be related to something else.
Old Aug 12, 2009 | 04:56 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: axle problem?
Axle or Wheel Bearing would be my bet.
Old Aug 14, 2009 | 05:00 PM
BLU CIVIC's Avatar
Track Advocate
alright, changed my axles...problem i described went away, but there's something new
drove the car around after changing the axles and everything seemed fine. but on the way home i got some vibration whenever i pressed the gas hard. also got vibration after taking a turn...so, any help
Old Aug 14, 2009 | 06:30 PM
monster_ls/vtec's Avatar
tire out of ballance...or still wheel barring
Old Aug 14, 2009 | 06:42 PM
BLU CIVIC's Avatar
Track Advocate
before there was a lot of vibration from a stop, but none of that, no pulling to the left or metal noise...checked the bearings and it's solid with no play...but i'm going to go over the car again in the am
Old Aug 14, 2009 | 07:36 PM
ef nine's Avatar
maybe it still the axels , cause i got the same problem like you before and the guy change my axel(pass' side) went to pick up and there's still vibration when i took off. took the car back ask him to check it again, and he end up change other axel.after the 2nd axel my car was ok no more vibration!!!
Old Aug 14, 2009 | 07:41 PM
BLU CIVIC's Avatar
Track Advocate
did you get another new axle? i've read about people having problems with new axles and having to replace them
Old Aug 14, 2009 | 07:59 PM
ef nine's Avatar
no, i got rebuild one, you know the way the shop do, they will order you new one (used but rebuild) then when they got it they took my messd up one out and replace with the rebuild one. then my car still got the vibration. took it back he take a look at the axel and told me that he gonna change to other one, got new one no more problem.......i mean all of the axel are all re build unless you want to buy like a new new one which it will coast you more!
Old Aug 14, 2009 | 09:30 PM
dseriesdemon's Avatar
does it clunk when you make any turns?
Old Aug 15, 2009 | 05:15 AM
BLU CIVIC's Avatar
Track Advocate
no clunking when i'm turning, just vibration when i hit the gas coming out of it
Old Aug 15, 2009 | 03:20 PM
Get the tranny inspected. I'll bet the crappy old driveaxles you had wore down the splines in the tranny. Weird thought, but I've heard of crazier. Might wanna just consider a whole tranny swap 2. if the clutch is still good, you can go to a ricer shop and pick up an si tranny for less than 300 and it'll be under warranty... Then check your new driveaxles while you have them pulled, and make sure the splines aren't messed up..
P.S. Don't forget that some tranny's are hydraulic, and others are cable... I almost had that happen to me, but i caught it before purchase.
Old Aug 20, 2009 | 06:24 AM
BLU CIVIC's Avatar
Track Advocate
i think i pinpointed the problem, or know where it's coming from...maybey you can hear it over the sound of my valves i think it's the axle...wasn't any problems until i put new axles on
Old Aug 20, 2009 | 06:54 AM
ernesttex111's Avatar
Sounds like a wheel bearing.
Old Aug 20, 2009 | 01:34 PM
check the brake dust plate and maby wheel bearing
Old Aug 20, 2009 | 06:13 PM
90civicstdgold's Avatar
When I noticed that same noise on my 90 Hatch it turned out to be that the axel itself was slightly bent. Which caused the vibration.
Old Aug 21, 2009 | 03:29 AM
BLU CIVIC's Avatar
Track Advocate
i'm replacing one side at a time this weekend
Old Aug 24, 2009 | 07:15 AM
BLU CIVIC's Avatar
Track Advocate
well changed the drivers side and the vibration was still there and started on the passenger side, but found a problem...can't get the axle out of the spindle. looks like the threads may have crossed...i've been hammering and using a pry bar since yesterday
Old Aug 24, 2009 | 08:11 AM
DO IT ON ALL FOURS
Sounds like the axle was not compressing the wheel bearing all the way because of the cross threaded nut not allowing full torque which in turn led to bearing failure.
Old Aug 25, 2009 | 07:07 AM
SETI20's Avatar
Sounds like an inner CV joint issue to me.
Old Aug 26, 2009 | 05:11 PM
BLU CIVIC's Avatar
Track Advocate
anyone know which spindle/knuckle will work other than an Si
Old Aug 28, 2009 | 12:51 AM
jenifertom90's Avatar
there is something very wrong with your lights.check it as soon as possible otherwise you will have to face much more problem than you have expected to have.
Old Aug 29, 2009 | 10:45 AM
BLU CIVIC's Avatar
Track Advocate
axles replaced, tires balanced...problem still there...wheel bearings next, after that...
emooheo
Jan 9, 2009 04:55 AM
808kyle808
17
Oct 22, 2008 07:21 PM
hyperlite1080
11
Apr 14, 2004 08:24 PM
REDBARON
14
May 24, 2001 07:25 PM
