Car not accelerating past 3k rpms.
Old Aug 12, 2009 | 02:40 PM
5thgenlude01's Avatar
Default Car not accelerating past 3k rpms.
When i had the car in the garage i could hit the gas and rev the car as high as i wanted, when i put it in first, went for a drive, everytime i hit 3k rpms the car sounded like it was backfiring and would not accelerate anymore, it did this in every gear at around the same rpms, i checked to make sure that the spark plug cables were tight and the main cable on the distributor was tight, dont know what else to do?
Old Aug 12, 2009 | 03:48 PM
duanes's Avatar
Default Re: Car not accelerating past 3k rpms.
It sounds like your catalytic converter may be plugged.
Try separating the exhaust pipe at the bottom of the manifold or BEFORE the cat.
It will be really noisy, but take a quick spin and see if you still have the problem.
Old Aug 12, 2009 | 06:34 PM
the_wrench116's Avatar
could be the cat or it would more likely be a fuel delivery problem. look into the cat first as that an easy thing to look at. next get a fuel pressure gauge and mount it to the fuel rail to make sure that your getting the right pressure at all loads. sounds like you have enough fuel to get to 3K and thats all she wrote. could be a filter thats pluged or a failing pump bent line anything that could be a restriction. good luck.
Old Aug 12, 2009 | 06:40 PM
E-Money's Avatar
Do no think it is a cat cause you will throw a code for it. and it will probably rattle too as well.
Old Aug 13, 2009 | 08:09 AM
TheCivicMafia's Avatar
Ill give u a list of things it could be.
Caddy
Fuel Filter
Distributor Ignitor ( im Positive by your disc this is it. I just fixed a problem like this )
Old Aug 13, 2009 | 07:16 PM
HondaVerno's Avatar
hmmm im having this same problem but for my 02 accord. cant be the cat, thats checked. fuel filter? just how would that be the problem?? dizzy ingitor? wth is that? LOL if you guys can find out that would be great
Old Aug 15, 2009 | 11:42 PM
HondaVerno's Avatar
Old Aug 15, 2009 | 11:45 PM
uNDERGROUND sTREET gOD's Avatar
is your speedometer working properly?
or do u have a chipped ecu?
I had a friend who decided to put an aftermarket tach on his car and accidently disconnected his speedmeter thing and his ecu kept making it backfire at 3k
Old Aug 15, 2009 | 11:57 PM
Akhany's Avatar
TPS sensor.
4tika4
29
Jan 26, 2010 02:06 PM
pos94accord
Nov 29, 2008 04:40 AM
Exodus Cycling
Honda Civic (2006 - 2015)
Apr 19, 2008 08:10 AM
95GSRDC2
Jul 13, 2007 04:19 AM
Red Bull Man
Sep 23, 2003 06:40 PM
