extended top hat?
Old Aug 12, 2009 | 01:24 PM
immajackuup's Avatar
Default extended top hat?
is it worth getting extended top hat?
kaiba's Avatar
Default Re: extended top hat?
yes and no. It depends.
Old Aug 12, 2009 | 01:44 PM
what u mean it depends?
Old Aug 12, 2009 | 01:55 PM
Anton LaVey's Avatar
if you knew what they were for then you would know what it depends on
Old Aug 12, 2009 | 02:03 PM
to give strut shaft more travel when u are lower instead of bottoming out.
so now tell me is it worth it or not.
i'm low on agx adjustable and the ride is rough.
Old Aug 12, 2009 | 02:13 PM
thumper64's Avatar
If you're hitting your bumpstops, it will help. If you just have new or really stiff springs, it won't help. It does take a while for your springs to "break in". I got Ground Controls on my hatchback and at first it was a bit stiff, but they softened up a little after a few thousand miles.
What size tires do you have? 16s or larger seem to ride harsh to me, 14s or 15s ride comfortably.
How low are you? Are you like an inch below stock, or are you scraping everywhere you go?
Old Aug 12, 2009 | 02:26 PM
here's my set up
st front/rear swaybar
agx adjustable
skuknk2 coilover.
tucking front tire/rear barely tucking.
riding on sparco ns2 wheel that are 15inch/tires 195/55
car ride hella smooth if i attack the corners but just for dd around places is bouncy and stiff but bottom out sometime when i hit mad bumps on the freeway.
Old Aug 12, 2009 | 02:28 PM
front
rear
money shot
Old Aug 12, 2009 | 06:21 PM
guess no1 likes me (-)(-)
Old Aug 12, 2009 | 06:43 PM
roadsqueegy95's Avatar
i like ur avatar!
Old Aug 12, 2009 | 07:03 PM
thumper64's Avatar
It shouldn't be bouncy. I'm not sure how well your shocks take to stiff springs, but maybe they're shot. And you're not going to get a soft ride with Skunk2s, they are some stiff springs.
Old Aug 12, 2009 | 07:18 PM
nah my shock aren't blown its bouncy because skunk2 coilover are stiff as hell,but still should i get extend top hat?
Old Aug 12, 2009 | 07:38 PM
thumper64's Avatar
If you're hitting bump stops, maybe. In the directions for installing my Koni Yellows, it said to cut the bump stops in half. You could try that first. Otherwise, you could buy extended hats from someone, or I should go in the business of making extended top hats...
Old Aug 12, 2009 | 08:06 PM
yes i did cut the bump stop and no i'm not bottoming out i think.
http://cgi.ebay.com/ebaymotors/96-00...lenotsupported
buying that top hat.
Old Aug 13, 2009 | 06:54 PM
no1 like my car?
Old Aug 13, 2009 | 07:00 PM
jkalex05's Avatar
Looks clean, drop is perfect.
Old Aug 15, 2009 | 05:29 PM
98civdx's Avatar
Master Detailer
i wouldnt, the ride is ruff do to the springs being stiffer then ****. i to have skunk coilovers. like them but werent designed to be comfy. possibly try setting the shock lower? that may help.
Old Aug 15, 2009 | 05:57 PM
batallic's Avatar
no1 like my car?
i like it thats the same height as mine
Old Aug 15, 2009 | 07:11 PM
Duc_du's Avatar
nice car i have black em1 too. im riding on pro kit which are almost comfortable as stock but it not low enough.
Razz2o4
Feb 24, 2019 04:13 AM
972drcordex
Jan 13, 2004 07:54 PM
deviant1
18
Nov 14, 2003 10:31 AM
azcivic
Mar 2, 2003 10:14 PM
01silverteg
Sep 23, 2001 04:14 PM
