Anything else to do while changing timingbelt/waterpump?
Old Aug 12, 2009 | 10:20 AM
ITRex's Avatar
Default Anything else to do while changing timingbelt/waterpump?
I called a few shops and most said that they change seals and hoses when doing the timing belt and waterpump. Can someone tell me what parts are these?
And can someone tell me the going prices to change these?
1. Clutch/flywheel- $750 dealer or 550 local mechanic.
2. Timing belt/water pump- Got qouted around $500
3. tune-up (I know I can do it myself, but have to pack and move within a few days. Thought I have my car repair while I use a uhual truck)
But I am still shopping around for cheaper places.
Have a stock 93 Honda Civic VX.
Old Aug 12, 2009 | 11:01 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Anything else to do while changing timingbelt/waterpump?
wow...that much money you can just buy a new motor for the vx
Old Aug 12, 2009 | 12:17 PM
sde780's Avatar
Do it yourself, really. Grow a set and try it, all you really need are 10-17mm sockets/wrenches and an impact/breaker bar
There's also eleventy billion writeups, I'll walk you through it if you post here
Old Aug 12, 2009 | 12:47 PM
Null zahlen's Avatar
If you only want a timing belt and water pump change, then just get that. For the timing belt, the only thing they do is replace the belt, no need to change any hoses or seals. For the water pump, it requires 1 seal on the water pump, which is usually included with the new water pump, no hoses or additional seals need to be changed. Another item that may need to be replace when doing the timing belt is the tensioner pulley.
bandit67
15
Jul 29, 2008 09:33 AM
pli
Oct 14, 2007 08:54 PM
infamousALLMTR
Mar 10, 2006 10:41 PM
B18C5-EH2
Jun 15, 2004 11:44 AM
RACING INTEGRATION
Mar 22, 2003 08:16 AM
