d16y8 swap in ef HELP
Old Aug 12, 2009 | 07:15 AM
basktb1188's Avatar
Icon6 d16y8 swap in ef HELP
ok i did the swap in my girlfriends ef... everyone that that helped me, THANKS!!!
anyway everything is in and i tried to start it last night and its got spark the rail has fuel pressure too... the spark is very weak and it turns over fast but no poping no smell of fuel nothing... could it be the injectors? there my ones off my d16a6 and the rail off d16y8...
any help would be great...
thanks,
brett
Old Aug 12, 2009 | 12:50 PM
basktb1188's Avatar
Default Re: d16y8 swap in ef HELP
injectors not moving or anything(poping)
need help
Old Aug 12, 2009 | 04:04 PM
black0hatch's Avatar
try hitting it with starter fluid. since you useing obd0 injectors are you still useing the resistor box?
Old Aug 12, 2009 | 04:18 PM
Canadian_EF's Avatar
you tried answering your own question?
are you using the resistor box. if you are, take it off, and solder all the wires from the green plug together.
Old Aug 14, 2009 | 06:01 AM
basktb1188's Avatar
i found the problem it was a ground wire that i missed... bolted it up , started first try! now i just got to find out where a big water leak is coming from...
luis007
11
Apr 6, 2016 04:33 AM
basktb1188
Aug 28, 2009 06:56 PM
jdm_h22
Jan 19, 2008 03:09 PM
quik1
Jan 26, 2006 12:20 PM
SSBGSR88
14
Apr 2, 2004 09:57 AM
