A difficult temp meter question
So one day it stopped working (the temp meter) and the other day I decided to try and fix it so I swapped in a known good sensor and that didn't fix it. Then I cleaned the connector and grounded it out. When I turned the key to the on position the needle went down farther than when the car was off (when I turned the car off the needle came back up). Does that make sense? It is like the polarity is switched...also after cleaning and putting in a known good sensor the meter still does not work. Is it a bad cluster then?
Luillo
Jan 25, 2013 08:44 AM
T_98 COUPE EJ7
Apr 7, 2011 11:07 AM
ef8sleepr
Mar 23, 2007 06:16 PM
C8V6C
Mar 27, 2006 09:01 AM
